Thread: DRLs with side lights?
Results 1 to 8 of 8
  1. DRLs with side lights?
    Mar 2007
    Brum
    Hi guys,
    Been playing with my vcds and trying out setting up DRLs as fog lights in the North American setting but just noticed that my side lights don't work nor the tail lights if I put the switch in the side light position all lights work fine in the dipped beam position. Have I missed a setting somewhere?
    Scottie
    2007 VW Touran Sport 2.0 TDI
    Pumpkin Android headunit
    1990 Mk2 Golf Driver 1.6, 1999 Passat SE 1.9 TDI, 2006 Passat Sport 2.0 TDI and 2012 Passat Est Sport 2.0 TDI - all gone but not forgotten.
  2. Re: DRLs with side lights?
    Sep 2008
    SE London
    Run indicators as DRLs here and have same effect under north American setting.
    Have light sensor so in that switch position, if gets dark or into a tunnel sides go on
    when dipped heads go full intensity. Think it's US regs? Only have wiring via a relay for
    fogs so can't check if same
    Running fogs if viz is >100M is an offence
  3. Re: DRLs with side lights?
    46 Post(s)
    Remember the American cars don't have a sidelight feature in their light switch, only off, auto (if fitted) and dipped beam.
  4. Re: DRLs with side lights?
    Sep 2008
    SE London
    Ah, so that's why all those threads about euro headlight switch in the US forums. Thanks
  5. Re: DRLs with side lights?
    Mar 2007
    Brum
    So it looks like a choice between Factory Fogs as DRLs and the use of side and tail lights then mmmm choices choices?
  6. Re: DRLs with side lights?
    Mar 2009
    York
    Strange. recently I had North America drls enabled and I have full sidelight function.
    However the same setting to my old 55 plate resulted in thd same loss of the sidelight position... If you notice though, when you've turned thd ignition off it works fine!
    A3 8V S-Line Cabriolet 2.0 TDI
    Passat B6 FSI • Passat TDI 105 • BMW E90 318d • BMW F30 320d Lux
  7. Re: DRLs with side lights?
    Sep 2008
    SE London
    Yes, the sides revert to parking lights -- I feel a truth table coming on
  8. Re: DRLs with side lights?
    Mar 2007
    Brum
    Anyone know if there's any adaptations which can be made to get the sides working in North American mode or to turn the tail lights and sides off in Scandinavia mode?
    Cheers so far fellas.
    Scottie.
  1. Bi-xenon lights don't have LED DRLs
    By G0rdon in forum Golf MK7 - 2013 - 2019
    Last Post: 17-02-2013, 06:49 PM
  2. 2001 Sharan TDi near-side head, side and tail lights not working.
    By di4charles in forum Touran - Sharan - Caravelle
    Last Post: 21-01-2013, 08:55 PM
  3. DRLs dash lights
    By Keithgardner in forum VCDS - Help Requests
    Last Post: 09-01-2013, 09:36 PM
  4. Question Upgrade to Bi Xenon lights with DRLs
    By JasonNing in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 02-02-2012, 09:36 PM
  5. led side lights and number plate lights, not working
    By adamk in forum Audi A3 - Archive Topics
    Last Post: 02-04-2008, 07:37 PM
