Thread: vw corrado g60 cambelt tension
  1. vw corrado g60 cambelt tension
    Mar 2008
    i have recently replaced the cambelt on my corrado g60 and was wondering how to exactly tension the belt because if you check the tension on tdc its tight but if checked at a random engine position when its turned off on the longest part of the belt its slack,also is the engine supposed to be hot or cold as hot the belt tightens up,i know its meant to be a 90 degrees turn on the longest part of the belt its just at tdc or not? cheers.
  2. corrado g60 crankbolt
    Mar 2008
    please can sombody help me find the correct torque setting in nm for the main crank pulley bolt(19mm 12 sided bolt),ive got a new one to replace the one that usually snaps but want to make sure its torqued correctly,cheers.
  3. Re: corrado g60 crankbolt
    Sep 2007
    Essex boy in Suffolk
    Bentley manual says 90Nm then a 1/2 turn (180°)
    Graham
    Still pretending to know stuff.
    Golf 6 .:R
    Corrado 20vT - BBS RCs, Leather, Bremo's, TFSI and DSG
  4. Re: vw corrado g60 cambelt tension
    Sep 2007
    set the tension by twisting to 90° then turn the engine over manually to check it ok then re-check the belt tension and tighten if required. All when cold.
    Graham
    Golf 6 .:R
  1. VW Corrado G60 Flange size..
    By AllanTX in forum Scirocco - Corrado
    Last Post: 05-10-2012, 01:24 PM
  2. selling my Corrado G60
    By Dubite in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 30-08-2008, 01:30 PM
  3. corrado g60 cutting out
    By simon hs in forum Scirocco - Corrado
    Last Post: 25-01-2008, 02:05 PM
  4. corrado g60 running problem
    By simon hs in forum VCDS - General Questions
    Last Post: 25-01-2008, 12:23 PM
  5. corrado g60 hell
    By nadagila in forum Archive posts
    Last Post: 02-10-2007, 02:21 PM
