Thread: 2.5 AKN Timing Figures
  1. 2.5 AKN Timing Figures
    Feb 2010
    bellshill
    Had the timing belt done in winter there.
    As my mate never had VCDS, he adjusted and adjusted till the car sounded ok and the following day I took the car out to try, and after some further adjustments the car was back to driving the way it was ( or at least felt like it) I have had a niggling tho to get a hold of another mates VCDS and check it out but until recently trying to get the car to read 80 degrees to get the figures has been nigh on impossible. tonigh however I have mannaged just that and hopefully if I copy n paste them someone will be able to disect and say wether they are good bad or indifferent.
    Thursday 2 May 2013 19:59:00:44319 VCDS Version: Release 11.11.5 (x64)
    8D1 907 401 2.5l/4VTEDC 0000AG D02
    Group A: '004
    Engine speed Spec. start Actual start Cold start valve
    TIME 3800-4200 rpm 10-14 *BTDC 8-16 *BTDC
    Marker STAMP /min °BTDC %
    0 835 Late 0 100.2
    0.38 835 Late 0 100.2
    0.76 835 Late 0.2 100.2
    1.13 835 Late 0.2 100.2
    1.51 835 Late 0 100.2
    1.9 835 Early 0 100.2
    2.28 858 Early 10.6 19.7
    2.66 835 Early 12.4 19.7
    3.04 835 Early 14.2 17.4
    3.42 835 Early 16.2 20.5
    3.8 835 Early 15.8 20.9
    4.16 835 Early 15.6 19.7
    4.53 835 Early 15.4 19.7
    4.92 835 Early 15.8 19.7
    5.3 835 Early 15.6 20.1
    5.67 835 Early 15.6 19.7
    6.04 835 Early 15.6 20.5
    6.42 835 Early 15.8 19.7
    6.78 835 Early 15.6 20.1
    7.16 835 Early 15.8 20.9
    7.55 835 Early 15.6 19.7
    7.95 835 Early 15.6 19.7
    8.33 835 Early 15.8 19.7
    8.73 835 Early 15.6 19.7
    9.12 835 Early 15.8 19.3
    9.49 835 Early 15.6 19.3
    9.86 835 Early 15.6 19.3
    10.26 835 Early 15.6 19.3
    10.65 835 Early 15.6 20.1
    11.02 835 Early 15.8 20.9
    11.41 835 Early 15.8 20.1
    11.77 835 Early 15.6 18.9
    12.14 835 Late 15.4 19.3
    12.52 835 Late 2.8 100.2
    12.89 835 Late 0 100.2
    13.26 835 Late 0.2 100.2
    13.63 835 Late 0 100.2
    13.98 835 Late 0.4 100.2
    14.34 835 Late 0.2 100.2
    14.7 835 Late 0 100.2
    15.09 835 Late 0.2 100.2
    15.48 835 Late 0 100.2
    15.85 835 Late 0 100.2
    16.22 835 Late 0.2 100.2
    16.61 835 Late 0.2 100.2
    16.98 835 Late 0.2 100.2
    17.36 835 Late 0 100.2
    17.72 835 Late 0 100.2
    18.1 835 Late 0.2 100.2
    18.47 835 Late 0 100.2
    18.85 835 Late 0 100.2
    19.23 835 Late 0.2 100.2
    Means absolute gibberish to me but hopefully something to someone,
    Thanks In Advance guys.
  2. Re: 2.5 AKN Timing Figures
    london/ UK
    If you have trouble to get the engine's temperature to 80 Celsius that means the thermostat is goosed and will need replacing- unfortunately is a cambelt off job ! If you have fully registered VCDS then you need to select the timing graph and see how the plotted line is...
  3. Re: 2.5 AKN Timing Figures
    Jul 2011
    Norway
    As Addams say, you need a new t-stat, the good news however is that the timing is ok. Spec is -2 +- 2 degrees ( 0-4 atdc.) yours is around 0, exactly where I would have set it.
  1. A6 2.5tdi AKN Timing Belt Change
    By MrAff in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-07-2023, 09:45 PM
  2. AKN 2.5 V6 Tensioner Problem
    By isodev in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-03-2013, 09:25 PM
  3. Afb akn change over????
    By fenboy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 14-10-2012, 09:59 PM
  4. 2.5D (AKN) Timing belt or belts?
    By Padwick in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-11-2009, 11:20 AM
  5. TDI injection timing 2.5 AKN
    By Trent in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 21-06-2009, 04:30 PM
