Thread: 1 Fault Found: 00283 - ABS Wheel Speed Sensor; Front Left (G47) allroad
  1. 1 Fault Found: 00283 - ABS Wheel Speed Sensor; Front Left (G47) allroad
    Jun 2008
    Lichfield, Staffordshire
    Hi folks, has anyone else had this fault come up after hitting a pot-hole ?
    Is it a new sensor or loose connection ? I've had a poke round and cables/connectors look tight.
    Fault shows instantly again when cleared.
    cheers
  2. Re: 1 Fault Found: 00283 - ABS Wheel Speed Sensor; Front Left (G47) allroad
    Mar 2008
    High Wycombe
    what does the text after the number say? Here's the link to the ross tech wiki page
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  3. Re: 1 Fault Found: 00283 - ABS Wheel Speed Sensor; Front Left (G47) allroad
    Jun 2008
    'open or short to plus' but I'm having no luck tracing the fault, is there a common break-point in the loom ?
    After a jolt going over a pot-hole, I'm thinking of tracing cable back to ABS ecu, where is it ??
    cheers
  4. Re: 1 Fault Found: 00283 - ABS Wheel Speed Sensor; Front Left (G47) allroad
    Oct 2005
    Check that the sensor is still where it should be. While you're there, check the face of the sensor for rust - it's magnetic and it attracts all sorts of debris
  5. Re: 1 Fault Found: 00283 - ABS Wheel Speed Sensor; Front Left (G47) allroad
    Mar 2008
    High Wycombe
    That shouldn't give "open or short to plus". That should give a low signal and show up in measuring blocks.
    Isn't the ABS ecu strapped onto the side of the ABS pump?
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  6. Re: 1 Fault Found: 00283 - ABS Wheel Speed Sensor; Front Left (G47) allroad
    Oct 2005
    I had the same code after working on my suspension - hitting the pinchbolts had caused the sensor to work its way loose which in turn increased the airgap between the face of the sensor and the brake disc.
    The rust was just a bonus
  1. ABS fault - rear left wheel sensor
    By leighmagill in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-04-2015, 03:24 PM
  2. front left speed sensor
    By tazmania_1981 in forum Golf MK4 - 1999 - 2004
    Last Post: 28-11-2010, 11:07 PM
  3. Please Help Front Left ABS Speed Sensor
    By idealsam in forum Polo - Derby - Lupo - Fox
    Last Post: 30-07-2009, 09:57 AM
  4. Where are these sensors? O2 - Lambda / MAF / ABS wheel speed rear left
    By p33tew in forum Polo - Derby - Lupo - Fox
    Last Post: 13-11-2008, 12:41 PM
  5. ABS - wheel speed sensor (s3)
    By Jon_Halibut in forum Audi A3 - Archive Topics
    Last Post: 15-06-2007, 03:08 PM
