Thread: The msterious golf Mk3 Judder/misfire problem!
  1. Question The msterious golf Mk3 Judder/misfire problem!
    Aug 2007
    Hi all,
    Recently my Golf Mk3 has developed a judder/misfire problem. When i accelerate the car seems to suffer from a misfire and it feels like it's being pulled back! It seems to happen mainly from 2nd gear upwards and is a real problem on the motorway as you can't biuld up speed.
    I took it into a garage and they checked the spark plugs, leads and air filter but after a test drive they couldn't find anything wrong with it! If you put your foot right down it doesn't seem to misfire!
    Is this a common problem? I'm afraid of taking it back into the garage due to cost without knowing a bit more about what it could be! HELP!
  2. Re: The msterious golf Mk3 Judder/misfire problem!
    rachull24 Guest
    Hi there, have you tried checking the throttle body, it may need a clean as they get a bit clogged up after some time & that can make the car bog down.
    Injector cleaner might also help if you haven't used any yet.
    Hope this helps to save you a trip to the garage.
  1. Clutch problem, hesitation, misfire?? You tell me...
    By Merry in forum Audi A3 - Archive Topics
    Last Post: 12-07-2007, 07:01 PM
  2. Help!! Golf Mk 3 Judder
    By eddiegrant in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 27-04-2007, 08:56 AM
  3. mk iv golf - judder
    By rickgti in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 21-04-2007, 12:22 AM
  4. Is the OCCASIONAL misfire a problem?
    By Rog in forum Polo - Derby - Lupo - Fox
    Last Post: 29-01-2007, 03:31 PM
  5. Mk3 Golf TDI Engine Judder
    By SteveC123 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 02-12-2006, 11:27 PM
