Thread: Radio problem in my A6 3,0 Tdi Q -08
  1. Radio problem in my A6 3,0 Tdi Q -08
    Apr 2013
    Nyland Sweden
    Hi , I have very bad Radion signal in my A6 3,0 Tdi -08 . I have replaced the anntena boster without any better signal.
    Do anyone know how to remove the radio part , and replace with a new one ? Or do you have any quick fix for these kind problem's ?
    Regards // Cgn
  2. Re: Radio problem in my A6 3,0 Tdi Q -08
    Nov 2009
    46 Post(s)
    Have you had a fault code scan done?
  3. Re: Radio problem in my A6 3,0 Tdi Q -08
    Apr 2013
    Nyland Sweden
    No , the Audi garage I checked with , will have 70-400 £ to do any investigation ,,, so I will try to fix in some way myself
  4. Re: Radio problem in my A6 3,0 Tdi Q -08
    Nov 2009
    46 Post(s)
    Without a proper diagnostic check we will fail to see what part(s) may need replacing.
  5. Re: Radio problem in my A6 3,0 Tdi Q -08
    Jun 2006
    I had the same issue with my 2005 car, it seems fairly common.
    In the end I installed DAB myself and I find the reception excellent and choice of stations far better. Not sure what DAB is like in your part of the world.
    Before spending big money hoping a new tuner module will fix it, I'd look to try and identify what is causing the problem.
    One way to do this could be to run a temporary aerial to the tuner, one you know is good, if it works then it's your aerial or wiring, if not then the tuner.
    Maybe a local AV specialist could do this for you at a reasonable cost?
    Just an idea.
    Good luck and keep us posted.
  1. radio problem
    By goldengrahams91 in forum In Car Entertainment
    Last Post: 21-03-2011, 07:20 PM
  2. Question Golf MK5 TDI Sport Radio Problem
    By sticky1 in forum Golf MK5 - 2004 - 2009
    Last Post: 07-03-2010, 03:07 PM
  3. Please Help Problem with Radio
    By Cheungy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-09-2009, 09:54 AM
  4. A6 Avant 2.5 TDI radio problem
    By mgoodwin in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 23-01-2009, 07:41 AM
  5. 98 A4 Radio problem.
    By glenniosaurus in forum Archive posts
    Last Post: 29-06-2006, 05:05 PM
