Thread: engine squeal
  1. engine squeal
    Mar 2009
    noticed a disconcerting squeal coming from my engine this morning on the drive to work. It is just discernable from the cabin with the windows up and starts as you come to a halt, so off throttle. Sounds quite loud when you are stationary with no road noise but then, as you pull away, it disappears.
    Any ideas what it might be? I'm guessing it's the auxillary/alternator belt.
    A
  2. Re: engine squeal
    Apr 2013
    Stoke on Trent, UK
    I would more or less garrantee it'll be the alterator slipper pulley, mine does exactly the same and i've seen or should i say heard loads of others do it as well i think it's pretty common and not too expensive to do.
    My cam belt is nearly due so i was going to get mine done then along with the water pump.
  3. Re: engine squeal
    Mar 2009
    Quote Originally Posted by Madmick001 View Post
    thanks Mick, I had the water pump and belts changed last year, but no idea if they changed the pulley. I've booked it in for them to take a look friday.
  4. Re: engine squeal
    Mar 2009
    Forgot to update on this, garage found that this was a split diaphram on the oil breather unit. Had them flumoxed for a while as the squeal was intermittent and had to tell where it came from in the engine bay. All sorted and running much better.
  5. Re: engine squeal
    Aug 2012
    London
    Would this squeal happen when u accelerate... I have squeal and it comes when ever I accelerate but it also comes when I leave the engine idling for 5 mins or so...
  1. turbo squeal
    By S1MON A3 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 22-08-2010, 06:19 PM
  2. Question 4.2 V8 Squeal during Kickdown for 0.5s
    By instrutec in forum A8 - S8 - V8
    Last Post: 21-09-2009, 01:15 PM
  3. electronic squeal from engine bay on 2003 A4
    By carlton1967 in forum Chat - Anything with wheels
    Last Post: 15-06-2008, 07:47 AM
  4. a4 brake squeal
    By rjohnson in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-03-2008, 01:34 AM
  5. Nearside squeal
    By Adpro2 in forum Audi A3 - Archive Topics
    Last Post: 23-12-2007, 01:44 PM
