Thread: 2.0TDI 143 Dipstick workaround part
  1. 2.0TDI 143 Dipstick workaround part
    Aug 2012
    Hampshire
    Seeing as my car has not got an oil dipstick at all, as its via MMI, I researched on the net.
    Most of the infomation I could find is either for the petrol or 3.0 versions.
    After playing around with a few oil dipsticks, what I have ended up doing is using the VW/Audi oil dipstick part 03L115611E.
    The dipstick itself is to long for my engine (2.0TDI 143) so after my mate had used his measuring device on the tube etc and cross referenced it, we ended up triming the bottom, cutting the plastic measuring part of, so you are left with the upper and lower grey plastic on the dipstick. Its not 100% precise, but using the upper and lower plastic parts on the dipstick as minimum and maximum I can get an approx reading, (which also matches with his universal adjuster dipstick and the MMI reading).
    Basically this means I now have a visual means other than relying on the MMI, it fits in place of the bung, and the engine cover still sits and clips in place.
    2013 A6 2.0TDi S-line
    Fully registered VCDS in Portsmouth & surrounding areas & fault diagnostics/resets on most other makes.
  2. Re: 2.0TDI 143 Dipstick workaround part
    46 Post(s)
    I (think) there was a guide put on here somewhere shaping how to fit it - when I'm back on my laptop this afternoon I'll have a look.
    Sent from my iPhone using Tapatalk 2
  3. Re: 2.0TDI 143 Dipstick workaround part
    Apr 2010
    Ireland
    Thanks Dieseldoos that's great to hear I can cut the dipstick down, would you happen to have the measurements you used?
    Chris did you happen to find the guide by any chance?
    Thanks for the help
    Shaun
  1. 2.0TDI 143 and 170, same clutch?
    By rufus2005 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 21-02-2013, 11:27 AM
  2. 3.0 TDI Dipstick part no
    By skymaster in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 16-02-2012, 02:48 PM
  3. Question A4 B8 2.0TDI 143 Starting Problems
    By ceegee in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 29-04-2011, 04:32 PM
  4. difference between 2.0tdi 143 vs 170hp
    By TigerDejan in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-10-2010, 10:00 PM
  5. 2.0TDi. 143 or 170bhp?
    By Audi Gav in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 16-09-2010, 10:47 AM
