Thread: MMI 2g hidden menu
  1. MMI 2g hidden menu
    Mar 2013
    Portishead, N.Somerset, England
    After reading many posts i think i know there are two hidden menus an“engineering menu“ and a proper hidden one that i probably need someone with a box of tricks to unlock.
    I have found the engineering one (setup & return , i think it was ) just left that one alone.
    What does each of these give access to?
    Is it worth me tracking down someone to unlock this? If it is anyone in Bristol / North Somerset
    MMI 2g high on a 2008 2.0 tdi pre-facelift
  2. Re: MMI 2g hidden menu
    46 Post(s)
    No real point unless you know what you're doing as one wrong click can brick the MMI.
    Only thing really is if you want the Battery Meter showing - it's wrong most of the time.
    To gain access you need to enable it first of all in VCDS (Control Head) and then press RADIO, wait, then press SETUP + CAR together (SETUP first then 1 millisecond later, the CAR) until the menu appears.
  3. Re: MMI 2g hidden menu
    Mar 2013
    Thanks Chris, i thought there may be more toys to play with for the sake of my curiosity what was the 1st menu i was in, what does that do (setup + return)
  4. Re: MMI 2g hidden menu
    46 Post(s)
    Setup+return gets you into firmware update mode iirc.
  5. Re: MMI 2g hidden menu
    Mar 2008
    11 Post(s)
    Chris, what do you mean by your battery meter comment?
    I have mine enabled and religiously watch it due to the two cameras I have in the car. Last month, had a flat after forgetting to charge up the battery over a 4 day non-driving weekend but anyway, everytime I check the meter, it seems to be correct.
    By this, I mean that when I get into the car every morning, the battery is usually on 1 or 2 bars (10/20%) as the cameras are on motion detect throughout the night. As I drive, it goes up and charges up the battery.
    The day the battery died completely, the MMI showed 0 bars from memory when I got the initial boost from the AA.
  1. MMI 2g 5570 update & hidden menu
    By piotrek in forum In Car Entertainment
    Last Post: 26-02-2015, 07:07 PM
  2. Accessing MMI Hidden Menu on Facelift B8 with MMI 3G
    By aled_31 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-04-2012, 08:34 PM
  3. MMI Hidden Menu
    By dragondownsouth in forum A8 - S8 - V8
    Last Post: 22-12-2011, 05:22 PM
  4. Accessing hidden menu on MY2010 3G MMI
    By MFGF in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-09-2010, 07:55 PM
  5. Accessing hidden menu on 2g MMI
    By MarkBS in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 12-03-2010, 03:34 PM
