Thread: DAB Retrofit to MMI 2G High .. Done! (again!)
Page 1 of 11 123 ... LastLast
Results 1 to 10 of 105
  1. DAB Retrofit to MMI 2G High .. Done! (again!)
    46 Post(s)
    I retrofitted DAB to my A6 must be 2 years ago now and found it very poor as my area hadn't good coverage.
    But since the Digital Switchover, the signal has improved dramatically (in the house) so I thought I would have another stab at DAB in the car.
    Ordered parts off eBay and they came within a few days.
    DAB Tuner - Audi A4 8K A5 8T A6 4F Q7 4L A8 4E DAB Tuner 2G 4E0 035 563 / 4E0 910 563 C | eBay
    Cabling - AUDI MMI 2G A4 A5 A6 A8 Q5 Q7 optical & electric harness PLUG&PLAY AMI, NAVI | eBay
    Aerial - http://www.dabonwheels.co.uk/Kinetic...ar_aerial.html
    In time I will fit the proper DAB quarterlight window, its less than £100 from Audi brand new and I can get the local Autoglass guys to fit it for less than £50.
    Tbh, the aerial makes all the difference, I drove 100 miles today and not once did the signal crackle or fade.
    I didn't remove the media rack, I just stuck my hand round the back of the DVD changer and unplugged the power and fibre cables and attached the piggyback loom to these.
    Antenna is mounted sideways in the rear quarter-light window, out of sight and out of mind.
    I also killed two birds with one stone as I removed the piece of trim above the seatbelt to find the source of a rattle (thanks Gup) it also allowed me to route the antenna cable down into the media rack out of sight.
    Also enabled 0F in the CAN Gateway for Digital Radio.
    Code:
    Address 0F: Digital Radio        Labels: None
       Part No SW: 4E0 910 563 C    HW: 4E0 035 563
       Component: DAB-Tuner       H41 0830
       Revision: 00000001    Serial number: KE1276U7400787
       Coding: 0000001
       Shop #: WSC 31414 790 00001
       VCID: 2443945EE71BD338654
    No fault code found.
    If anyone wants any help etc feel free to ask
    3 4 0
  2. Re: DAB Retrofit to MMI 2G High .. Done! (again!)
    Nov 2012
    Somerset UK
    Am doing mine in May so this was helpful, especially given I had no idea they did a rear quarterlight with DAB ariel for the saloon...could you post the part no please?
    Just as an aside, am guessing the temp aeriel is secured by way of jamming the tip in the quarterlight trim? If so and the base is loose won't this lead to an annoying rattle against the glass?
    I have a local place that have 5 of the DAB units and will fit it inc pigyback wiring (but sans aerial) for £185.
  3. Re: DAB Retrofit to MMI 2G High .. Done! (again!)
    46 Post(s)
    PN for window - 4F5 845 299 H NVB
    You'll also need a little amplifier but I haven't researched this yet and is very cheap by glancing online.
    Yep thats how I secured it, doesn't rattle but if it does I will stick it with something but I'll do that if the needs done.
    You should try doing it yourself, first time it took me just over an hour, but this time done less than 30minutes as I had better knowledge this time.
    Although if you're letting the firm fit it, make sure they have VCDS to enable the 0F Digital Radio in the CAN or you'll be left with a load of errors and potentially reduced performance.
  4. Re: DAB Retrofit to MMI 2G High .. Done! (again!)
    Nov 2012
    Somerset UK
    Thanks Chris!
    Yep they have VCDS
  5. Re: DAB Retrofit to MMI 2G High .. Done! (again!)
    46 Post(s)
    Excellent, keep us updated and when I get round to doing the window I'll update too.
  6. Re: DAB Retrofit to MMI 2G High .. Done! (again!)
    Apr 2009
    Preston
    Hey chris where in the back of the saloon is the rack ?
    Sent from my GT-I9305 using Tapatalk 2
    Y90USF
  7. Re: DAB Retrofit to MMI 2G High .. Done! (again!)
    46 Post(s)
    In the boot, on the left hand side behind the removable panel.
    Sent from my iPhone using Tapatalk 2
  8. Re: DAB Retrofit to MMI 2G High .. Done! (again!)
    Mar 2012
    Ireland
    6 Post(s)
    Has anyone done the DAB retrofit to a 3G MMI DVD system, I'm interested in the upgrade but cant see where to start.
    Dave N
  9. Re: DAB Retrofit to MMI 2G High .. Done! (again!)
    Jul 2011
    Near Uxbridge
    Check out my thread 'the day the music died' .....I did it when the dreaded rear washer pipe split at a joint and fried my radio and satnav box in the boot.
    Neil
    Sent from my phone...
    Consultation en ligne viagrasansordonnancefr.com immunite des francais
  10. Re: DAB Retrofit to MMI 2G High .. Done! (again!)
    46 Post(s)
    few more miles done today and there was only one small crackle going under some trees, all other times were spot on so i can safely say the aerial choice was a good one
  1. Replies: 30
    Last Post: 14-09-2016, 10:26 PM
  2. Replies: 35
    Last Post: 31-01-2016, 06:54 PM
  3. Replies: 25
    Last Post: 27-09-2012, 06:34 AM
  4. Dab retrofit help
    By mrmarc in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-11-2011, 10:10 PM
  5. A6 DAB retrofit
    By RickB in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 27-04-2007, 12:18 PM
