Thread: Who's afraid of the big bad fuel filter change?
Results 1 to 10 of 12
  1. Who's afraid of the big bad fuel filter change?
    Nov 2011
    Duns Scotland
    11 Post(s)
    No, not me - any longer! Dreaded havng to do this every 2nd service on my 2002 Audi Allroad 2.5Tdi AKE Auto. This time I clamped off the hose from the fuel tank and the hose to the IP with two pairs of long nose grips (insulation tape wrapped round jaws to prevent crimping hoses). Then disconnected/replaced filter and bingo - car sarts first time AND KEEPS RUNNING!
    SUGGEST THIS COURSE OF ACTION FOR CHANGING FUEL FILTER AND ALSO IP (only the second clamp requred). Hope this helps someone like me who flattens the battery every time trying to get the engine started again!
    2 1 0
  2. Re: Who's afraid of the big bad fuel filter change?
    May 2012
    Glasgow
    Me.
    thanks for that though, will remember that trick for next service!
    2001 A6 Avant 1.9tdi 130 manual AWX 203k+++ "Come to kindly terms with your @ss for it bears you." - John Muir.
  3. Re: Who's afraid of the big bad fuel filter change?
    Mar 2011
    Kendal Cumbria UK
    Also helps to fill the filter when fitting the new one!
    Dan
    2002 A4 B6 2.5 TDI Quattro Sport - Mods to date... Too Many To List!
  4. Re: Who's afraid of the big bad fuel filter change?
    Nov 2011
    Duns Scotland
    11 Post(s)
    Quote Originally Posted by dan.taylor.1 View Post
    Dan
    Thanks for that Dan - I do but forgot to mention this IMPORTANT fact!
  5. Re: Who's afraid of the big bad fuel filter change?
    Aug 2012
    London
    Great tip
  6. Re: Who's afraid of the big bad fuel filter change?
    May 2012
    Nr Barmouth Gwynedd
    I just fill the filter up and turn her over, if she doesnt start after a few cranks then just pop the securing pin holding the hoses in and fill to the brim again, then continue turning her over till she starts, if the battery starts to fade I just hook her up to the tranny. all done in less than 3 mins. Good idea about clamping mind if you cant jump it.
    2002(52) AUDI ALLROAD QUATTRO 2.5 V6 TDI AUTO TIPTRONIC
    1996(N) 300 series Discovery XS 3.9 V8 efi, manual, single point LPG converted
  7. Re: Who's afraid of the big bad fuel filter change?
    Nov 2011
    Duns Scotland
    11 Post(s)
    Hi folks. Just thought I would input this. 2 Years down the line and I have just changed the fuel filter again. Same procedure - clamp the two hoses, fill to brim new filter with diesel, connect up and release clamps. Engine starts first time and continues running. DEFINITELY THE WAY TO DO THE JOB !
    1 1 0
  8. Re: Who's afraid of the big bad fuel filter change?
    Nov 2011
    Duns Scotland
    11 Post(s)
    Another two years on - just changed the fuel filter. Started first time - not even a stutter. CLAMP THOSE TWO HOSES - WAY TO GO!
  9. Re: Who's afraid of the big bad fuel filter change?
    Mar 2014
    Aylesbury Bucks
    19 Post(s)
    Yes definitely works! I just clamp the supply hose not the return. Then pour the fuel out of the old filter into a measuring cylinder out of the OUTLET port so no dirt comes out. Then after checking for dirt and water pour into the new filter. Car stars first go, miss-fires a bit then runs fine.
  10. Re: Who's afraid of the big bad fuel filter change?
    Nov 2011
    Duns Scotland
    11 Post(s)
    Bluezie - a week before the fuel filter change I clamped and removed just the inlet hose to replace the N75 valve behind it. When all done, I too had a slight misfire! I would advise everyone to clamp both hoses to be safe.
    Also, I am not sure it is a good idea to re-use the fuel in the old filter. I thought its main job was to trap water - might be wrong here.
    ..and this is coming from a Scotsman!
  1. PD fuel filter change?
    By bk.bas99 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-02-2011, 09:16 PM
  2. fuel filter change
    By ad777 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-09-2010, 07:10 PM
  3. fuel filter change
    By mf6480 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-04-2009, 06:14 PM
  4. erratic idling & bad fuel consumption.... need new air filter element?
    By cara_essex in forum Golf MK3 - 1993 - 1999
    Last Post: 16-11-2007, 10:07 PM
  5. Bad News Im Afraid
    By jamie211983 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-04-2007, 04:29 PM
