Thread: Who's afraid of the big bad fuel filter change?
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. Re: Who's afraid of the big bad fuel filter change?
    Mar 2014
    Aylesbury Bucks
    19 Post(s)
    That's why I use a measuring cylinder to decant the fuel, and fill the new filter through the thermo valve hole so the 'old' fuel gets filtered before entering the pump. In all the years of servicing diesel engines, I've never had one drip of water come out of the filters, even from the old type that have a water drain valve at the bottom. I must be lucky with fuel quality, and if any water has got in, it must be still in the bottom of the fuel tank.
  2. Re: Who's afraid of the big bad fuel filter change?
    Nov 2011
    Duns Scotland
    11 Post(s)
    Just successfully changed the fuel filter again. This time I used a small "artist" paintbrush to lightly cover the seal for the valve and also lightly coated the two tubes on the filter for the hoses. Both valve and hoses slipped on very easily. This avoids possibility of crimping the seal when pressing on the valve. Hope this update helps someone.
  1. PD fuel filter change?
    By bk.bas99 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-02-2011, 09:16 PM
  2. fuel filter change
    By ad777 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-09-2010, 07:10 PM
  3. fuel filter change
    By mf6480 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-04-2009, 06:14 PM
  4. erratic idling & bad fuel consumption.... need new air filter element?
    By cara_essex in forum Golf MK3 - 1993 - 1999
    Last Post: 16-11-2007, 10:07 PM
  5. Bad News Im Afraid
    By jamie211983 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-04-2007, 04:29 PM
