Thread: A6 2002 1.9tdi 130ps - Air Con Failure
Results 11 to 20 of 26
  1. Re: A6 2002 1.9tdi 130ps - Air Con Failure
    Nov 2011
    Duns Scotland
    11 Post(s)
    Quote Originally Posted by nigel63 View Post
    my aircon has packed up,just scanned it and it gives me the code G65,my question is where is this sensor located?
    it comes up with the message 0819 high pressure sensor
    29-00- short to ground
    01592 air quality sensor g238
    37-00 faulty.
    just as the better weather is coming i thought i would turn on air con coming home from work and it wont come off econ.
    Remove front bumper. G65 high pressure sender is located top right side of condenser. Remove electrical connection, remove G65. Reinstall with NEW o-ring, 5nm torque. Check first it is not a wiring problem.
    Looks like you also need an air quality sensor g238 as well!
  2. Re: A6 2002 1.9tdi 130ps - Air Con Failure
    Aug 2006
    thankyou for such a quick reply,i need to replace the cambelt very soon so i will check the wiring and replace the switch if needed as the bumper needs removing to do the cambelt. thanks again...nigel
  3. Re: A6 2002 1.9tdi 130ps - Air Con Failure
    Nov 2011
    Duns Scotland
    11 Post(s)
    If you need the full instructions for doing the cambelts (water pump and thermostat as well when you are in there!), pm me your full car, engine, gearbox details and e-mail address and I will send you the pdf files.
  4. Re: A6 2002 1.9tdi 130ps - Air Con Failure
    I think the G65 location is dependant on which car it is. I haven't removed mine yet but it looks like on my A6 it's mounted on the left hand side of the A/C rad. Check out the link below for the A4 location. It's a good instruction but I think you may get away with just removing the headlight :-
    How To Change the G65 Aircon Thrust/Pressure Sensor
  5. Re: A6 2002 1.9tdi 130ps - Air Con Failure
    Nov 2011
    Duns Scotland
    11 Post(s)
    Quote Originally Posted by johnnywishbone View Post
    Standing in front of car, G65 is on right side ie. passenger side. Yes it is close to headlght but manual says to remove bumper first. You might get away with it - update this post with the answer please!
  6. Re: A6 2002 1.9tdi 130ps - Air Con Failure
    Aug 2006
    Quote Originally Posted by ceilidhalfie View Post
    Thankyou for you kind offer,i really appreciate it,i will pm you my email address now.thankyou once again.
  7. Re: A6 2002 1.9tdi 130ps - Air Con Failure
    #17
    Jan 2006
    PRESTON, LANCS
    NO NEED to remove front bumper at all (if it's the same as mine).
    10 minutes of a job-at the most-- easy peasy .
    £35 ish for the part (from memory).
    Lots of info on it on here --if you look.
    it IS to the right of the DRIVERS SIDE headlight (looking towards the car from the front.
  8. Re: A6 2002 1.9tdi 130ps - Air Con Failure
    #18
    Aug 2006
    my cars a 52 plate 1.9tdi pd se.saloon.. what is yours?
    Also does anyone know the part no for the g65 sensor.
  9. Re: A6 2002 1.9tdi 130ps - Air Con Failure
    #19
    Jan 2006
    PRESTON, LANCS
    It's the same 53 reg. 1.9TDI
    You dont need the part number-- just call main dealers and tell them G65 and they will know.
    It is a very common fault .
    ps- dont forget to ask for the 'o' ring too.
    It REALLY is easy to do .
  10. Re: A6 2002 1.9tdi 130ps - Air Con Failure
    #20
    Ok, so finally got around to changing the G65 but here's a cautionary tale for anyone about to carry out this job. I 've had two wasted return journeys trying to get the correct part and eventually got it direct from my local Audi dealer. In hindsight I could've saved two gallons of fuel by doing this in the first place....doh !!!! GSF and Euro both supplied me with the wrong part but not totally their fault because even Audi told me today that there are at least 4 different versions of the part for my car alone !!! Anyway, as I said in one of my previous posts, I managed to access the pressure switch by just removing the headlight (see pics). On my A6 the pressure switch is on the driver's side of the air con rad whereas I've seen lots of pics of A4's and even some A6's where it's mounted on the passenger side. See the pics I've attached which shows the original pressure switch in-situ and the new part from Audi.
    I hope this helps someone.
    Cheers,
  1. Please Help 2002 Golf TDI PD150 - Air Con not working
    By mhd143 in forum Golf MK4 - 1999 - 2004
    Last Post: 02-06-2011, 08:48 AM
  2. Air Con suddent failure
    By tails in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-05-2009, 09:59 PM
  3. air con still not working on a4 tdi 2002
    By kangtdi in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-06-2008, 11:18 AM
  4. Please Help A3 1.8SE 2002 Rattle noise with air con on .
    By 2002A31.8 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 10-05-2008, 07:29 PM
  5. 2002 Polo heater/air-con probs
    By Midge in forum Polo - Derby - Lupo - Fox
    Last Post: 02-03-2008, 11:58 PM
