Thread: 109 relay
  1. 109 relay
    May 2007
    kendal,cumbria
    Any know where the 109 relay is located on A3 tdi, the one that gives starting problems etc. on diesels.
  2. Re: 109 relay
    Dec 2007
    Quote Originally Posted by kow View Post
    Installation is literally a snap. After removing the driver's side under-dash panel (two T-15 Torx screws), simply use a flashlight to look-up where the fuses are and remove the largest fuse - Relay 377 - and carefully set it aside.
    Directly above the empty slot (where Relay 377 used to be) is Relay 109, which can now easily be removed and replaced. Everything can now be put back together in reverse order.
  3. Re: 109 relay
    May 2007
    kendal,cumbria
    Thanks for that Yes2 ram, have since solved the problem, it turned out to be a vacuum leak on the brake vac lines. Crap Audi design feature which they have since changed.
  1. Relay Box
    By john Mc Grath in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-12-2007, 12:52 PM
  2. Intermittent Wiper Relay - HELP!
    By Steve P in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-06-2007, 01:00 PM
  3. indicator relay
    By Yogi in forum Audi A3 - Archive Topics
    Last Post: 28-04-2007, 03:17 PM
  4. relay click
    By stubbsy in forum Audi A4 - Archive Topics
    Last Post: 12-02-2007, 02:50 AM
  5. wiper relay
    By alanled in forum Touran - Sharan - Caravelle
    Last Post: 22-01-2007, 11:21 PM
