Thread: passat 05 rear o/s door deadlocked shut!!!!!!
Results 1 to 9 of 9
  1. Unhappy passat 05 rear o/s door deadlocked shut!!!!!!
    Apr 2013
    peterlee, uk
    I would be very grateful if anybody could help with my locked door, after checking wires leading into the B pillar was fine, all wiring leading upto and into the door is fine. I have managed to strip out my door completely and there is only the lock left in the door and i still can't manipulate the mechanism from the inside to open it.....HEEELLLLLPPPPPPP!!!!!!!!!
  2. Re: passat 05 rear o/s door deadlocked shut!!!!!!
    disconnect the battery, and two pulls on the door handle should open it, if you don't disconnect the battery it will not open,
  3. Re: passat 05 rear o/s door deadlocked shut!!!!!!
    Apr 2013
    peterlee, uk
    Cheers for the suggestion but this did not work either, however I have managed to open it since posting this, I cut a hole in the plastic casing of the central locking motor and wound the dead lock off manually thus being able to pop the button or the lever connecting to it then open the door from the outsde. This will make it much easier to unbolt the door catch when the new lock arrives.
  4. Re: passat 05 rear o/s door deadlocked shut!!!!!!
    Apr 2009
    Cymru
    Quote Originally Posted by big G 05 View Post
    Sorry to resurrect this rather old thread , but can you tell me how you "wound the dead lock off manually" ? I have an A3 in a similar situation but both o/s doors are the same - can't open from the inside or outside. Thanks
  5. Re: passat 05 rear o/s door deadlocked shut!!!!!!
    1840 Post(s)
    Which A3; 8L, 8P or 8V? You would get better results by starting your own thread.
  6. Re: passat 05 rear o/s door deadlocked shut!!!!!!
    Apr 2009
    Cymru
    It's an 8P so similar chassis to the Passat B6? I have already started my own thread: Deadlocked Door Advice
    but there hasn't been any responses to any of my messages.
    Sent from my SM-N950F using Tapatalk
  7. Re: passat 05 rear o/s door deadlocked shut!!!!!!
    Nov 2014
    United Kingdom
    Anybody any idea on this? I've started another thread bit waiting approval I think! 53 Passat rear door won't open! Door card off, inner skin off, lock disconnected from power, won't open! 😥
  8. Re: passat 05 rear o/s door deadlocked shut!!!!!!
    May 2012
    Everywhere
    308 Post(s)
  9. Re: passat 05 rear o/s door deadlocked shut!!!!!!
    Nov 2014
    United Kingdom
    Had a look here, everything I already knew!! Door was shut so couldn't do it this way!!
    Having perceived at it this afternoon I managed to open the door by completely trashing the lock from the inside with my multi-tool.
    Couldn't see why it didn't open but now need to get a replacement fairly sharpish as door is now left open with window gaffered closed!
  1. Passat R/N/S Door Locked Shut
    By jim_tdi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-11-2010, 04:18 PM
  2. Passat rear door deadlocked, help!
    By gezmason in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-08-2010, 11:25 PM
  3. Please Help Rear Door Stuck Shut Please help.
    By OilyKnight in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-12-2009, 07:29 PM
  4. Rear Door Deadlocked Shut
    By frustrated9 in forum Golf MK4 - 1999 - 2004
    Last Post: 11-03-2009, 08:03 PM
  5. Please Help Mk 4 rear door stuck shut
    By giggsy07 in forum Golf MK4 - 1999 - 2004
    Last Post: 11-12-2008, 12:40 PM
