Thread: golf 1.4 16 v t reg shuddering and misfiring whilst driving help please
Results 1 to 8 of 8
  1. golf 1.4 16 v t reg shuddering and misfiring whilst driving help please
    Mar 2013
    bristol
    wondering if any one can help we bought a golf 1.4 16v T reg 2 months ago
    since we have had it it has had a full service as it looked it it had not been done for a while
    all the filters were blocked and useless.
    since we have had it all done we are getting shuddering and misfiring and cutting out while driving
    Its been to the garage and put on the machine and no faults have come up
    can anyone shed some light as to what it is ? as its bordering on dangerous to drive
    thanks sue
  2. Re: golf 1.4 16 v t reg shuddering and misfiring whilst driving help please
    Jan 2009
    towcester northants
    try a set of plug leads as they fail
  3. Re: golf 1.4 16 v t reg shuddering and misfiring whilst driving help please
    Mar 2013
    bristol
    thanks for reply
    we have replaced all the leads and spark plugs thermostat and all the filters but its still doing it
    its a pain in the ****
    Its been on the machine and the garage can't find anything wrong with it
  4. Re: golf 1.4 16 v t reg shuddering and misfiring whilst driving help please
    Jan 2009
    towcester northants
    Quote Originally Posted by blusher View Post
    thanks for reply
    is it registering any codes?
    i have had a couple of egr valves fault and cause a missfire under load
    i would also check the map sensor in the side of the inlet manifold as they allways play up and cause different issues usually rough running bad idle
  5. Re: golf 1.4 16 v t reg shuddering and misfiring whilst driving help please
    Mar 2013
    bristol
    Hmm found out why it was shuddering
    the Gearbox is knackered the gearbox crown wheel plate rivets has sheared off and put a hole in the side of the gearbox
    Oh well more money to find
    New Gearbox and Clutch on the way
    least hubby can fix it so that is some good news
  6. Re: golf 1.4 16 v t reg shuddering and misfiring whilst driving help please
    Aug 2011
    Meath
    What did the garage scan it with? You need VCDS or VAS-PC for these cars. It could be one of several sensors or the throttle body
  7. Re: golf 1.4 16 v t reg shuddering and misfiring whilst driving help please
    Mar 2013
    bristol
    throttle body has been changed the coil pack themostat sender new rad plugs all new filters
    we had a bang under the car the other day and hubby checked and had oil leaking from the gearbox
    so he took it apart and hey pesto had a hole in the gearbox housing inside the bellhousing or summat
    gearbox and new clutch being fitted tommorrow
  8. Re: golf 1.4 16 v t reg shuddering and misfiring whilst driving help please
    Mar 2013
    bristol
    wow what a difference 24 hours makes
    new gearbox ( second hand ) and a new clutch
    the car now drives like a golf
  1. heater motor? and unusual shuddering whilst stopped
    By dieselal in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-08-2011, 05:32 PM
  2. Please Help Airbag light on whilst driving
    By Matt_1990 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 07-09-2010, 01:40 PM
  3. VWT4 1999 Auto 2.5tdi. Shuddering whilst driving...
    By pblucas in forum The Commercial Range
    Last Post: 21-01-2010, 11:41 AM
  4. Photo'd whilst driving
    By JLamy in forum Chat - Completely Off Topic
    Last Post: 24-06-2009, 11:06 PM
  5. 1.4 16v 2000 x reg golf misfiring still
    By dean-nez in forum Golf MK4 - 1999 - 2004
    Last Post: 07-05-2008, 12:53 AM
