Thread: A2 management light on!
  1. A2 management light on!
    Mar 2013
    inverness
    Hi folks, just picked up my first A2 today. Lovely motor in great nick. Drove 14 miles then management light came on. Flashing at first then stayed on. Also oil warning icon appeared. Panic. Started to lose power but decided to pull off the road to investigate. Checked oil level, fine. As i`m no mechanic i called AA. They diagnosed the fault as being a code P03 02. Is this a common problem and is it expensive to remedy.
    Thanks in advance from a newbee
    Tony
  2. Re: A2 management light on!
    Mar 2013
    Edinburgh UK
    If you google the fault code it says its a coil pack. Not really that expensive to repair but best get it booked in to a garage to have it properly diagnosed if it is still running alright as if it the coil packs away it would be running a bit lumpy and you'd notice. You're other option is take it back if it was a garage you got it from
  3. Unhappy Re: A2 management light on!
    Mar 2013
    inverness
    Hi bud, bought the car privately. The guys not returning my calls now.
    The car runs fine after starting no problem, its only after a few miles its a bit jittery. Put some petrol in at the station and it went great for a bout 2-3 miles then would splutter a bit then fine. managed to get home eventually. A bit worried about a big bill at the moment though!
  4. Re: A2 management light on!
    Nov 2009
    46 Post(s)
    For curiosity's sake, I would be calling Audi as there was a recall on some petrol models for failing coilpacks.
    You could also ring customer service on 0800 699888 .. No harm in trying.
    Welcome to VWAF!
  5. Re: A2 management light on!
    Mar 2009
    Essex
    If its a 1.6 FSI, a well known problem. If you google it you'll find plenty of owners links.
  6. Re: A2 management light on!
    Mar 2013
    inverness
    Hi Chris, should have mentioned its an 02 plate.
  7. Re: A2 management light on!
    Mar 2013
    inverness
    Hi Chris, put the car to Audi. diagnosed as faulty injector. £505 later, they call me to say management light of problem solved. BUT when they road tested it they said there was a flat spot at 3500 and that the oil pressure light came on.
    No luck eh! what could be going on there then?
  8. Re: A2 management light on!
    Mar 2009
    Essex
    Quote Originally Posted by jankow777 View Post
    Have you tried the A2 forum A2OC.net?
    Just like here but full of A2 obsessives. And truly helpful.
    Sorry mods if not allowed to promote another forum....
  1. Question My engine management light doesnt light up at all?
    By Nuss in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-07-2011, 10:46 AM
  2. Please Help a3 1.8t management light again!!
    By ricardo33 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 30-03-2010, 03:47 PM
  3. management light
    By fmj750 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-06-2009, 10:42 PM
  4. A4 Engine Management Light
    By EBO13 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-05-2008, 07:11 AM
  5. Engine Management Light
    By Chris Russell in forum Audi A3 - Archive Topics
    Last Post: 07-10-2007, 02:59 AM
