Thread: Turbo Over boost- Limp mode
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
  1. Turbo Over boost- Limp mode
    Dec 2012
    Norfolk
    Dear Friends, The car is losing power sometimes on motorway and goes to Limp mode. The mechanic told me that you need a new turbo. The car runs fine and in limp mode if I stop car and start again the problem is gone. It does same after some time but not regularly.
    Replacement cost is too much and I would welcome any other ideas, like cleaning the unit etc. Someone advised to use the Forte Turbo cleaner??
    Can you please guide if Turbo can be cleaned to get rid of this problem and any local in Norfolk area who does this job.
  2. Re: Turbo Over boost- Limp mode
    Aug 2011
    Meath
    Is the turbo boosting normally before it goes into limp mode?
  3. Re: Turbo Over boost- Limp mode
    Mar 2008
    Just Cumbria now.
    If I was the OP, I'd get a fault code read before doing anything else.
    Otherwise it's pure speculation.
    Nothing to see here, move along..
  4. Re: Turbo Over boost- Limp mode
    Dec 2012
    Norfolk
    Yes Odd, the turbo works normal before going to limp mode. I gave the car to a local VAG specialist to diagnose the fault and they come up with the statement that turbo is over boosting and charged me £45.
  5. Re: Turbo Over boost- Limp mode
    Aug 2011
    Meath
    You need to get a scan and post the codes on this forum, also read this VNT turbo disassembly and how to replace or repair stuck vanes on VW TDI engine
  6. Re: Turbo Over boost- Limp mode
    Feb 2010
    luton uk
    qalaray
    it might even trace back to a £48 solenoid sensor if your lucky , reason i say that is you have boost no boost turn off then back on and you have boost then lose it again . do you know the fault codes you had ?
    "A pessimist sees the difficulty in every opportunity; an optimist sees the opportunity in every difficulty."
    Winston Churchill
  7. Re: Turbo Over boost- Limp mode
    Dec 2012
    Norfolk
    there is no fault on car computer. The mechanic said it has sticky vanes and thats why it is showing over boost.
  8. Re: Turbo Over boost- Limp mode
    Norfolk
    Quote Originally Posted by qalaray View Post
    Your mechanic is probably right.
  9. Re: Turbo Over boost- Limp mode
    Feb 2010
    luton uk
    [QUOTE=qalaray;796802]there is no fault on car computer. The mechanic said it has sticky vanes and thats why it is showing over boost.[/QUOTE
    most people come on here to get advice but obviously you come on here to tell us you trust your mechanic and he's right , i hope he is . i only gave you my thoughts on the matter
    Winston Churchill
  10. Re: Turbo Over boost- Limp mode
    fella , try changing the map sensor that sits in the intercooler pipe ontop near the bulk head . that was the problem with mine . I had fault codes stored that pointed me in this direction .I changed every vacuum pipe first - didn't work , I got some spray cleaner for the internals of the turbo - didn't work, I changed the n75 valve - didn't work, also just turn off the ignition and back on whilst you drive and the boost will come back for a while , no need to keep on parking and turning the engine off.... 4 garages said to me sticky vanes and £1000 , how wrong they were..... good luck ...
  1. Question Is this Limp Mode? No turbo boost and clicking noises
    By adani24 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-03-2013, 10:37 PM
  2. 1.4 tsi boost problems limp mode
    By deutsch in forum Golf MK5 - 2004 - 2009
    Last Post: 29-02-2012, 11:57 PM
  3. Please Help No turbo boost, limp mode
    By bambamjj in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-02-2012, 08:41 PM
  4. Please Help Limp mode loss of turbo boost
    By dan2134 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-07-2011, 03:11 PM
  5. Please Help boost cutting out and limp mode
    By 90karl90 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 20-05-2009, 06:18 PM
