Thread: Turbo Over boost- Limp mode
Results 11 to 20 of 26
  1. Re: Turbo Over boost- Limp mode
    Aug 2006
    Quote Originally Posted by passat 130 tdi View Post
    fella , try changing the map sensor that sits in the intercooler pipe ontop near the bulk head . that was the problem with mine . I had fault codes stored that pointed me in this direction .I changed every vacuum pipe first - didn't work , I got some spray cleaner for the internals of the turbo - didn't work, I changed the n75 valve - didn't work, also just turn off the ignition and back on whilst you drive and the boost will come back for a while , no need to keep on parking and turning the engine off.... 4 garages said to me sticky vanes and £1000 , how wrong they were..... good luck ...
    Ive had to change my MAF sensor about 5 times over the last 7 years. Its definitley a DIY type job. Parts cost about 70 - 80 pounds:
    Looks something like this : Volkswagen Passat 2.0D TDi Diesel (2003-) Air Mass Sensor: Amazon.co.uk: Car & Motorbike
  2. Re: Turbo Over boost- Limp mode
    Mar 2013
    Brierley Hill
    Quote Originally Posted by genghis View Post
    I'm pretty sure the chap you quoted was on about the MAP sensor not the MAF - from my own experience MAF's are either dead or not- haven't come across a intermittent one and the ecu substitutes values when dead in any case. I'm pretty sure the MAP failing will throw you into limp home as a precaution to stop over boost.
  3. Re: Turbo Over boost- Limp mode
    Aug 2006
    Quote Originally Posted by S66MJETDI View Post
    You're in danger of confusing this whole topic. Click on the link I have provided. That part is what i have replaced. Several times. It's fixes the following symptoms: limp mode driving on the motorway. Intermittent power loss. Miss firing of the turbo!!
  4. Re: Turbo Over boost- Limp mode
    maf and map are 2 different parts . the map measures absolute pressure and shuts down the turbo , maf controls fueling etc ... S66MJETDI is correct in what he/she said .
  5. Re: Turbo Over boost- Limp mode
    Aug 2006
    I don't particularly care if the opinion is technically right or wrong . I'm more concerned with answering the original question with a solution of the symptoms. The original poster can ignore the advice (a cheap fix that works). Had I taken the experts advice I would had to pay hundreds for a turbo!
  6. Re: Turbo Over boost- Limp mode
    Aug 2011
    Meath
    So what did you do?
  7. Re: Turbo Over boost- Limp mode
    #17
    Mar 2013
    Brierley Hill
    Pleased for you. Not only are you the first person I am aware of to have a failing MAF throw the car into Limp...... but you have also CHANCED across the solution.
  8. Re: Turbo Over boost- Limp mode
    #18
    a cheap fix you say ??? 5 mafs over 7 years at £80 a pop £400. I haven't changed a maf yet in 123000 miles and only had problems following a remap which upped the boost in the system and the MAP didn't like it , the parts I replaced to cure limp mode cost me in total £ 78 , I think he should avoid your advise and listen to others with a lot more posts than 4 and a lot more knowledge of the passat tbh .
  9. Re: Turbo Over boost- Limp mode
    #19
    Feb 2010
    luton uk
    and if you've changed it 5 times in 7 yrs i reckon you should get an original vw one then
    "A pessimist sees the difficulty in every opportunity; an optimist sees the opportunity in every difficulty."
    Winston Churchill
  10. Re: Turbo Over boost- Limp mode
    #20
    Feb 2010
    luton uk
    +1
    Winston Churchill
  1. Question Is this Limp Mode? No turbo boost and clicking noises
    By adani24 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-03-2013, 10:37 PM
  2. 1.4 tsi boost problems limp mode
    By deutsch in forum Golf MK5 - 2004 - 2009
    Last Post: 29-02-2012, 11:57 PM
  3. Please Help No turbo boost, limp mode
    By bambamjj in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-02-2012, 08:41 PM
  4. Please Help Limp mode loss of turbo boost
    By dan2134 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-07-2011, 03:11 PM
  5. Please Help boost cutting out and limp mode
    By 90karl90 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 20-05-2009, 06:18 PM
