Thread: Turbo troubles
Results 1 to 10 of 13
  1. Turbo troubles
    Oct 2009
    Hampshire
    Hi chaps.
    After 50k of trouble free motoring the car suddenly lost power and gave me some flashing dashboard lights on the motorway last week. I took it to my local indy who pronounced the turbo as being kapput with no vacuum and with fault code p0299 (underboost) Refurb replacement would be £900.
    Before I bite the bullet, has anyone else had anything similar crop up and if so what did you do about it?
    At the moment the car still works and everytime I turn the ignition off it resets and the turbo works again for a while and bizarrly thrashing it a bit helps stave off the flashing lights but I need to get it sorted soon as driving along waiting for the lights is no way to carry on.
    Mant thanks
    Shadow CC
    p.s. still love the car after 50k and 3.5 years just hope it's not going through a mid life crisis
  2. Re: Turbo troubles
    Norfolk
    Go to a proper garage. Get a proper vcds code read done. That code is usually a vacuum fault but not of you have a newer engine model. What engine have you got?
  3. Re: Turbo troubles
    Oct 2009
    Hampshire
    Quote Originally Posted by martin1810 View Post
    it's a 2.0 CR 140 diesel on a 2008 manual CC.
    I was just trying to avaoid VW as long as I could as I'm pretty sure it would lead to a more expensive version of the Indy's Turbo replacement quote. However that's going to be my next step but a little knowledge always helps discussions so I'm grateful for your advice
    Shadow
  4. Re: Turbo troubles
    Norfolk
    The turbo actuator on those is a well known weak point. You need a proper scan to confirm it. You won't need a new turbo, just a new actuator.
  5. Re: Turbo troubles
    Jul 2008
    Quote Originally Posted by Shadow CC View Post
    Hi chaps.
    I have had a recent experience on my CC where I had a turbo fault code. I'd do as Martin says - I had a proper code scan done and post up the results.
    Mine was an actuator - from what Martin and Crasher say, it appears this is a very common issue on our engine codes.
    This may be the issue with yours and will be a HELL of a lot cheaper than replacing the entire turbo. My fault with the actuator was electrical, yours sounds mechanical (Vacuum - the diaphram being split perhaps?). There is a repair kit out there - part code 03l198716a.
    I would look into this as a probable cause to your issues before replacing the turbo.
  6. Re: Turbo troubles
    Oct 2009
    Hampshire
    Thanks for the advice chaps. I'll check it out and let you know what the outcome is.
    Shadow CC
  7. Re: Turbo troubles
    Oct 2009
    Hampshire
    Hi chaps
    Just to update you all I rang a mate of a mate who is a VW mech and he came up with the same conclusion. The actuator kit was £120 and his time was £50 and it is all now working fine and dandy.
    So thanks (Dave & Martin)for pointing me in the right direction and saving me quite a few quid.
    Shadow
  8. Re: Turbo troubles
    Jul 2008
    Hi chaps
    Shadow
    £170 - massive difference to the £900 you were originally quoted. Just goes to show, it's best to ask before shelling out big bucks. That's the value of forums such as this!
  9. Re: Turbo troubles
    May 2009
    Aylesbury Bucks
    Hi lads
    Do you know if i have to take off turbo to change actuator valve or it can be done without touching turbo??Because VW quoted £400 for changing it.
  10. Re: Turbo troubles
    UK Ex-pat now in Australia
    Quote Originally Posted by Conrad83 View Post
    Hi lads
    No it is done with the turbo remaining in situ - its a bit fiddly and requires a diag machine to set it up correctly.
    Had MKV GTI, Now Ford Falcon
  1. turbo troubles (tdi)
    By jimicks in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-12-2010, 10:19 PM
  2. Possible turbo troubles... HELP
    By b.a.r.k.e.r in forum Chat - Anything with wheels
    Last Post: 16-03-2009, 12:55 PM
  3. Turbo/vac line troubles
    By willster in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-12-2008, 12:39 AM
  4. turbo troubles!! please help
    By J-DiZZle in forum Golf MK4 - 1999 - 2004
    Last Post: 05-01-2008, 08:59 PM
  5. golf 1.8t turbo troubles
    By giraffe100 in forum Archive posts
    Last Post: 22-01-2007, 01:14 AM
