Thread: Touran oil leak
  1. Touran oil leak
    Hello
    I just discovered oil under our Touran. It wasn't there this morning (it was parked nose-in) so has happened today after a shortish journey, about 10 miles.
    It's due an oil change so I'm going to do that. It's the PD engine so will it have the plastic oil filter housing like the Bora/Golf? Or does it have a proper metal one that screws into the sump?
    Any known weaknesses that could cause a sudden oil leak? Blocked breather etc?
  2. Re: Touran oil leak
    Jan 2009
    towcester northants
    plastic oil filter
    have you hit the underside of the car on a speed hump? if so check for cracked sump
    check intercooler hoses as these seep
  3. Re: Touran oil leak
    It did start to leak quite suddenly but I don't think I hit anything... I'll have a good look on Thursday when I get chance.
  4. Re: Touran oil leak
    If anyone's interested it turned out to be the oil feed pipe to the turbo.
    A stainless steel, rigid pipe unsupported for its entire length. It's going to crack with vibration eventually. I suppose a P clip would have been too expensive.
  5. Re: Touran oil leak
    We now have another leak, one year on to the date of the last one.
    It's not as acute as last time, I suppose I'm going to get the undertray off & have a look.
  6. Re: Touran oil leak
    This is taken from underneath - it's leaking from the nut in the middle of the pic (the one above/further away than the one on the oil scavenge pipe flange). I tightened it as much as I dared but it's still dripping about once every seven seconds at tickover.
    Can I get seals for these turbos, or does it have to be rebuilt?
    Thx
  7. Re: Touran oil leak
    May 2009
    London
    Quote Originally Posted by 3narf View Post
    Thx
    Hi, did you manage to fix this leak?
  1. Question Touran 2005 1.9tdi Fuel Leak
    By richard3009 in forum Touran - Sharan - Caravelle
    Last Post: 03-01-2012, 11:17 AM
  2. Question fuel leak and oil leak
    By nc7503 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-07-2011, 10:10 PM
  3. Audi A4 1.9 TDI (110) Oil leak and Possible boost leak?
    By officialuk in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-02-2011, 10:45 AM
  4. Slight oil leak foward of oil filter 1.8T
    By rhencullen1989 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-03-2010, 09:44 PM
  5. Please Help touran passanger side front and rear wet leak leaking
    By drunlock in forum Touran - Sharan - Caravelle
    Last Post: 18-01-2009, 10:36 PM
