Thread: MMI 2G/Phone module problem?
Results 11 to 20 of 22
  1. Re: MMI 2G/Phone module problem?
    #11
    Oct 2012
    London
    Yes, optical bridge connected now and music is not cutting off anymore, the whole MMI is not slow any more etc. It was all BT module fault.
    If BT is dead, usually it's cutting off Optical chain, that's why it looks like Component Protection is active. You need to run diagnostic, then you'll know what's wrong. Otherwise you need to get access to where BT Module is located and plug MOST Loop/Bridge and see if it helps...
    Only in AUDI I trust..
  2. Re: MMI 2G/Phone module problem?
    #12
    Nov 2009
    46 Post(s)
    I don't think the BT module's have CP?
    My genuine Audi module in my A3 certainly didn't.
  3. Re: MMI 2G/Phone module problem?
    #13
    Oct 2012
    London
    Yes, BT doesn't have component protection. I think, symptoms which are caused by faulty BT Module are similar to when Component Protection is active..
  4. Re: MMI 2G/Phone module problem?
    #14
    Oct 2012
    London
    Hello people,
    So after waiting for a long time, finally my BT Unit arrived, I installed it and I can say that it's working fine now. I've sent my faulty Unit to Eastern Europe for repairs, as it was cheapest option for me (don't ask me how I found someone to fix it, I spent long hours to find someone who can do this) and now it's back to normal.
    Also, I've done MMI firmware updates and now it's 5570.
    However, I have few questions regarding updates.. I made notes of Software Index of all MMI module before I started updates and after I've done all updates possible, I can see that my:
    CD-Changer (SW-Index: 0470), DAB-Tuner (SW-Index: 0830) and Gateway (SW-Index: 0070) did NOT update. Navibox D3 also did not update, but I believe it'll update together with DVD update disc. Right? I've run all 3 CDs as per instructions and all the process went without any problems.
    So, does anyone have an idea why these 3 module did not update? Is it because there were no updates for these modules on a set of 3 Update CDs or is it because these modules were up to date?
    So my MMI modules have these SW-Indexes:
    Interfacebox: SW-Index: 5570
    CD-Changer: SW-Index: 0470
    Handyvorb2: SW-Index: 1130
    DSP-High C6: SW-Index: 0240
    Tuner EU/US/RDW: SW-Index: 0630
    NaviBox D3: SW-Index: 0850
    Dab-Tuner: SW-Index: 0830
    Gateway: SW-Index: 0070
    Can someone please confirm that no further updates are needed for my setup?
    Thanks a lot
  5. Re: MMI 2G/Phone module problem?
    #15
    Oct 2012
    London
    Hi again, only today I realized that in CAR meniu there's no "Version" option any more. It disappeared after updates.
    Anyone know how to unable this option using VCDS?
  6. Re: MMI 2G/Phone module problem?
    #16
    Sep 2011
    Lurking over a keyboard ...
    Quote Originally Posted by Darius R View Post
    So my MMI modules have these SW-Indexes:...
    Hi chap ... mine is a 2005 A6 Avant MMI 2G High with std.speakers (9VD = Speaker (active)) ... I retrofitted DAB, rest is factory fitted ...
    It had MMI FW v2120 I updated to FW v5570 ... recently got SAT NAV disc 2013 ...
    Code:
    Address 07: Control Head        Labels: 4F0-910-7xx-07-H.lbl
       Part No SW: 4F1 910 732 D    HW: 4E0 035 729
       Component: Interfacebox    H43 5570
    Address 0E: Media Player 1        Labels: 4E0-910-111.lbl
       Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
       Component: CD-Changer      H44 0470
    Address 77: Telephone        Labels: 4E0-910-336.lbl
       Part No SW: 4E0 910 336 M    HW: 4E0 862 335
       Component: Handyvorb2      H10 1130
    Address 47: Sound System        Labels: 4F0-910-223-AS.lbl
       Part No SW: 4F0 910 223 G    HW: 4F0 035 223
       Component: Amp.-ASK        H09 0350
    Address 56: Radio        Labels: 4E0-910-541.lbl
       Part No SW: 4E0 910 541 T    HW: 4F0 035 541 B
       Component: TUNER EU/US/RDW H42 0630
    Address 37: Navigation        Labels: 4E0-910-88x-37.lbl
       Part No SW: 4E0 910 888 P    HW: 4E0 919 887 C
       Component: MNS ECE         H44 1060
    Address 0F: Digital Radio        Labels: None
       Part No SW: 4E0 910 563 C    HW: 4E0 035 563
       Component: DAB-Tuner       H41 0830
    Address 19: CAN Gateway        Labels: 4F0-910-468.lbl
       Part No SW: 4F0 910 468 A    HW: 4F0 907 468 B
       Component: Gateway         H09 0030
    Hi again, only today I realized that in CAR menu there's no "Version" option any more. It disappeared after updates.
    Only suggestion I can make contact Ross Tech support via email, they also do visit the VCDS section on VWAF perhaps one of their reps will answer their ...
    Even if they have no procedure to resolve issue you maybe able to gain info on resetting relevant MMI module to factory defaults and coding in options/adaptations from them ...
    If I see anything when rooting around for stuff will post mate ...
  7. Re: MMI 2G/Phone module problem?
    #17
    Oct 2012
    London
    gupsterg, thank you so much so actually, everything looks OK really in terms of SW-Indexes of those modules, looks like there were no more updates for them..
    I just can't figure it out how come "Version" option is not there any more. I did read quite a few threads about MMI updates and missing features afterwards but did not see anyone mentioning they lost "Version" in CAR meniu.
    Maybe I should just reboot MMI system one more time...
    However, Thank you for info from your log, now I see that I updated everything I could
  8. Re: MMI 2G/Phone module problem?
    #18
    Sep 2011
    No worries , I think all is OK RE SW-Indexes ...
    I'd give that a whirl ... what I was suggesting in my earlier post is factory reset on module 07 Control head ... via adaptation ...
    Channel 00 is a special case. Performing a [Save] to Channel 00 resets all adaptation values to their original factory defaults. This only works in controllers that support this function, see your Factory Repair Manual to find out if this procedure applies to each controller in your vehicle.
    As a genuine VCDS owner RossTech will give you email support to let you know what you need to note or advise if above will help you, I lack experience to guide you on the pitfalls/outcome of factory reset ...
  9. Re: MMI 2G/Phone module problem?
    #19
    Oct 2012
    London
    I feel a bit stupid now before the updates to access "Version" function I needed to press CAR ant then lover right button. Now it changed the location. Now it's located under CAR-SETUP-Settings. Don't ask me how I missed that - I don't know. I was looking everywhere before and didn't see it
    So all good now
    Thanks for your help
  10. Re: MMI 2G/Phone module problem?
    #20
    Sep 2011
    What was your original FW before update mate? ...
  1. MMI updating with phone module removed
    By mckenna in forum A8 - S8 - V8
    Last Post: 23-11-2012, 08:41 PM
  2. 3G MMI phone connection problem
    By Woody24 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-05-2011, 06:59 PM
  3. Audi A4 MMI and I-Phone 3GS Snyc Problem
    By MHunt in forum In Car Entertainment
    Last Post: 11-04-2011, 03:34 PM
  4. Audi A8 - TV Module/PS3/Ipod Etc/MMI
    By devine_nathan in forum A8 - S8 - V8
    Last Post: 10-07-2010, 01:36 PM
  5. Mmi - Which Phone
    By steve.link in forum A8 - S8 - V8
    Last Post: 05-01-2008, 07:38 PM
