Thread: A6 2.5 TDI slow to pull away from idle
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. A6 2.5 TDI slow to pull away from idle
    Aug 2012
    London
    It is a 2.5 TDI SE auto.
    The engine runs fine and pulls well when it is in higher revs but the problem is that from idle it takes a couple of seconds to start moving, i.e. once revs have picked up.
    This is a tad dangerous as, especially at roundabouts, pulling away is too slow
    Any help or advice on what it could be or what to check for?
    thanks
  2. Re: A6 2.5 TDI slow to pull away from idle
    Mar 2009
    Cotes d"Armor, France
    When was the oil last changed in the multitronic box? Should be every 40K but some recommend 20K
    `05 1.9 TDI 130 Avant Multitronic - 4B5 06H - AVF HB9 Final Edition
  3. Re: A6 2.5 TDI slow to pull away from idle
    Dec 2009
    southampton uk
    I assume you are saying that the engine is slow to rev not the gearbox is slow to respond.Suggest you get it checked on diagnostics for faults cos it sounds like an eletrical issue
  4. Re: A6 2.5 TDI slow to pull away from idle
    Aug 2012
    London
    Quote Originally Posted by ellaguru2u View Post
    Not sure tbh, I'll need to check. It does have a fsh though (long life)
    Quote Originally Posted by mikeybutch View Post
    It feel more like the box is slow to respond, the revs pick up, a bit slowly, but it doesnt pull instantly.
  5. Re: A6 2.5 TDI slow to pull away from idle
    Mar 2007
    9 Post(s)
    Quote Originally Posted by Rudidudi View Post
    thanks
    have you had the car long as this recently started . i used to own a4 2.5tdi quattro and the turbo lag was shocking nothing under 1800 to 2000 rpm then the turbo kicked in and it flew they takes some getting used to especially at junction and rounabouts
  6. Re: A6 2.5 TDI slow to pull away from idle
    Aug 2012
    London
    Quote Originally Posted by sbt View Post
    just got it today, its not turbo lag imo, it is literally stationary until the revs pick up.....
  7. Re: A6 2.5 TDI slow to pull away from idle
    Mar 2009
    My box is getting ready for a change next service. The oil was changed just before I acquired the car and pulling away was fine but it is definitely slow first thing in the morning recently, especially on cold mornings. Once its warmed up its fine. Is yours behaving similarly?
  8. Re: A6 2.5 TDI slow to pull away from idle
    Aug 2012
    London
    Mine seems the same even when warm...
  9. Re: A6 2.5 TDI slow to pull away from idle
    Mar 2009
    The only other thing I can think of (we're nearing the envelope of my limited knowledge now) has it had a 7 clutch conversion (from the original, and problematic, 6 clutch unit. This was an Audi manufacturers fix for a design fault with the multitronic box. Your FSH should show if it has or not.
  10. Re: A6 2.5 TDI slow to pull away from idle
    Feb 2013
    Liverpool
    I would check all air intake pipework.....I had same thing when I had not tightened up hose going into turbo, you put your foot down and nothing.
  1. Jerking passat when cold and slow pull away
    By coltam in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-11-2016, 09:23 AM
  2. A6 2.0 TDI - doesn't pull for long?
    By eddie_fb in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 25-02-2011, 09:16 AM
  3. slow A4 2.5 tdi
    By wavey-davey in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-07-2009, 08:48 PM
  4. slow A4 2.5 TDI
    Last Post: 11-07-2009, 12:14 PM
  5. Went to see a TDI 150 and it was slow.
    By raven8472 in forum Golf MK4 - 1999 - 2004
    Last Post: 05-07-2009, 10:44 PM
