Thread: Air con problem, not the usual issues...
  1. Air con problem, not the usual issues...
    Mar 2010
    edinburgh
    Hey folks,
    The A/C on my 2006 B7 has started to either blow cold, or blow hot with very little inbetween. Set it to 17c and you'll get cool air, 17.5 and its pretty hot, although not as hot as it'll go. Its became a bit of a battle when driving between cooking and freezing... It's also slightly irratic in that setting both sides to the same temp can sometimes result in different temperatures coming out each side of middle vent.
    I've checked with Vag-Com and no faults are reported, also done a basic setting but thats not helped.
    When the basic setting is running number 5 seems to stay at 255, but i would need to double check to confirm this.
    I recently replaced a flap motor after the arm on one snapped. That was around a month ago and the install followed by basic setting had everything working like new, so may be related, but hopefully not...
    Any ideas or suggestions?
    Ross
    B7 A4 2.0Tfsi Quattro SLine Special Edition.
    Full Vag-Com, Edinburgh.
  2. Re: Air con problem, not the usual issues...
    Dec 2009
    southampton uk
    I would check the flaps again
  3. Re: Air con problem, not the usual issues...
    Southern County Softy
    20 Post(s)
    If #5 stays at 225 the flap mitor is not moving
    I wish I could tpye...
    A4 2.5 tdi QS (mapped)
  4. Re: Air con problem, not the usual issues...
    Mar 2010
    edinburgh
    Bloody flaps, I'll have a look...
    Dont suppose you know which one number 5 is? Its dual zone air con
    Cheers guys
  5. Re: Air con problem, not the usual issues...
    20 Post(s)
    Not sure which one.
    You could remove the glove box and watch the motors.
    The motors can be removed and regreased as the wirm drive tends to dtick.
    Try google for a "how to"..
  1. 1999 Audi A4 Air Con issues
    By neilhewett in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-09-2013, 10:08 AM
  2. Air Con issues
    By b1nuzz in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-11-2012, 04:59 PM
  3. Please Help Issues following air con re-gassing
    By Jones the Horse in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 19-07-2012, 10:06 AM
  4. Air Con Issues - driving me nuts
    By diesel-a4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-10-2008, 07:09 PM
  5. Air Con issues
    By ronmcintosh in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-08-2007, 12:10 PM
