Thread: cluster in safe mode. wont start
Results 1 to 10 of 16
  1. cluster in safe mode. wont start
    Oct 2012
    shoreham by sea
    Stupidly decided to clean out the dust from cluster!!
    On reinstalling had a msg where the total mileage is... Fuse and after that safe.
    Tried starting but died after two seconds.
    Took out back on checking pins and contacts but at this point had the ignition on!!!
    Tried resetting with removing batt terminals,now the central locking dont work and every time i get in car alarm goes off.
    My little code reader found 4 faults relating to
    Drive train missing
    ac fuse
    coolant temp sensor
    and imobilizer?
    Been advised again to check contact points again.
    Dont know what else to do.
    1.9 130 avant (04)
    Based (stuck in shoreham)
    Near brighton
    Why did i bother! Have done this b4 with no issues
  2. Re: cluster in safe mode. wont start
    Aug 2011
    Meath
    What did you read the codes with? Are the leads plugged into the cluster fully? Take it out and make sure none of the pins are bent. Is the immobiliser light flashing?
  3. Re: cluster in safe mode. wont start
    Feb 2009
    To get the Central locking working, you switch on the ignition with the key you want to "enable", switch it off, remove the key and "lock" the car.
    Try the following as well:
    1. Disconnect both battery & connect battery leads (short them) with a jumper wire - removes any residual curent. Wait 5-10 minutes.
    2. Reconnect battery, place key in ignition & initiate reprogramming sequence.
    3. Sequence = turn key to "ON" position only, wait 10 seconds. Repeat 5 times.
    * you can also try pressing the unlock buttons, both on the fob while in the ignition & the door button.
    Hold each for 5-10 seconds while key is "ON", both individually & together during each "on-off" sequence.
    You could also check the cables from the immobiliser - though unlikely to be the cause.
    W.
  4. Re: cluster in safe mode. wont start
    Oct 2012
    shoreham by sea
    The coil light is flashing. Checked pins,all seem ok.
    Just a basic code reader.
    Il post the numbers later
    it found 4faults
  5. Re: cluster in safe mode. wont start
    Jan 2011
    derby UK
    Quote Originally Posted by deano1978 View Post
    it found 4faults
    Your problem is alsmot definetly the immobiliser. I get the same if car is started with valet key - runs for 2 sec then cuts off. Also, if you put your key in ignition while holding 'unlock' then move to ignition on for 2 sec then back of and take the key out. At the point when you take the key out release 'unlock'. This programs the key. Otherwise, you have to disconnect the battery for reset then once reconnected repeat above.
    Hope it helps
  6. Re: cluster in safe mode. wont start
    Oct 2012
    shoreham by sea
    How do i go about sorting this if its the immobilizer?
    Il try the key mode when im back indoors.
    Thanks for help guys.
  7. Re: cluster in safe mode. wont start
    Oct 2012
    shoreham by sea
    Sending me mad.... Key process not working not responding when unlocking the door manually,only driver door unlocks and alarm goes off. I wait for alarm to stop, but while waiting the front and rear indicators constantly blink. Alarm stops but lights still blink
    So i put keys in ignition and alarm goes off again.
    Just cant stop or switch alarm off!. The light diode on door is not flashing while in the car but alarm keeps going off.
    Stoping now as neighbours as proberly getting annoyed.
    Only have one key to top it off.
    Now what....
    HELP........PLEASE
  8. Re: cluster in safe mode. wont start
    Aug 2011
    Meath
    Do a cold boot. Take both terminals off the battery and hold them together for 30 seconds or so. Then leave them off for half an hour. Connect them and see if the car starts. If not you'll need a scan done
  9. Re: cluster in safe mode. wont start
    Oct 2012
    shoreham by sea
    Quote Originally Posted by Doctle Odd View Post
    Thanks will do 2moz.
    Proberly going to take it to a vag specialist.
    Just got to get it there 1st.
  10. Re: cluster in safe mode. wont start
    Aug 2011
    Meath
    Did you check if any members with VCDS are close to you, chances are one would drop over and scan your motor, here's the map. VWAF User Location Map - VCDS - Google Maps
    By deano1978 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-03-2013, 08:51 AM
  2. Audi Instrument cluster car wont start
    By rhysvw in forum VCDS - Help Requests
    Last Post: 02-09-2010, 11:03 PM
  3. Question Limp mode/safe mode
    By fourringsrus in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 20-01-2010, 02:06 PM
  4. Safe mode?
    By grover in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-02-2009, 06:23 PM
  5. VW radios in safe mode?
    By BugsyMalone666 in forum Chat - Anything with wheels
    Last Post: 04-05-2008, 04:52 PM
