Thread: Inlet cam 2.0 tdi...which one?
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: Inlet cam 2.0 tdi...which one?
    #11
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Hi, dont get me wrong, I like your quest for accuracy, but in the years I worked at a VW dealer, we never had to set any adjustment on cams for what symptom your describing, or, had that symptom after a belt change. Yes, we did dynamic timing on the EDC pumps, but thats as it says, Pump Timing.
    Let us know how many goes you had and if you sussed it.
    Alan.
    VW T6 150 DSG Camper £££
  2. Re: Inlet cam 2.0 tdi...which one?
    #12
    Oct 2007
    S.Wales
    Had the idle problem/hunting on mine whilst warming up but fine when up to temp, I believe others suffer the reverse. The problem with mine only started after a Cambelt change and a quick tweak of the cam as described sorted it. Perfect now. Inlet cam is on the right as you look at the engine.
    07' A4 Avant 170 S Line, Lava Grey, Two Tone Leather, RNS-E
  3. Re: Inlet cam 2.0 tdi...which one?
    #13
    Mar 2008
    Excellent, glad this thread helped you smithen999.
    2007 A4 Tdi 2.0 140 S-Line
  4. Re: Inlet cam 2.0 tdi...which one?
    #14
    Aug 2016
    Scotland
    hi. is this fuel consumption around 0.4l/h or 0.6l/h must be with AC on or off.
  5. Re: Inlet cam 2.0 tdi...which one?
    #15
    Sep 2021
    ​This is the most useful information I have found so far. The thing is, when I rotate the intake cam on mine clockwise, the number moves more negative. I was assuming a negative figure therefore is advanced?
  1. A6 2.0 Tdi Inlet manifold actuator
    By JimC64 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-01-2013, 04:10 AM
  2. 3.0 Tdi Cam belt or cam chain
    By l14m in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-05-2012, 07:42 AM
  3. Inlet manifold V6 TDI
    By hbsteer in forum Touareg
    Last Post: 03-03-2011, 07:13 PM
  4. Please Help Oil in inlet on TDi
    By dubdaze in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-12-2008, 10:30 AM
  5. Tdi inlet pressure
    By JonG in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-11-2008, 10:59 PM
