Thread: Alternator belt tensioner + Alternator clutch pulley - time and money?
Results 1 to 8 of 8
  1. Alternator belt tensioner + Alternator clutch pulley - time and money?
    Dec 2012
    Peterborough
    It looks like I need to have the above changed. Car has developed a rumbling vibration noise. Following guidance on here I have tried turning the metal fan in the alternator in both directions and it seems stuck in one direction and pretty much stuck in the other (certainly not easy to move move than a few mm at a time).
    When the engine is running the metal fan does spin but the alternator belt tensioner seems to be vibrating a great deal (assuming that is the component with the big bolt on it on the far bottom left of this picture below).
    Can someone tell me how much I should expect to pay in parts for a new alternator clutch pulley and alternator belt tensioner? and how much in labour?
    Thanks!
  2. Re: Alternator belt tensioner + Alternator clutch pulley - time and money?
    Aug 2011
    Meath
    You need to let the tension off the drive belt to check the alternator. A lot of mechanics will put the car in the service position (front off) for this job. Parts wont be too expensive and you'd be as well to change the belt at the same time. 200-250.00 I'd estimate
  3. Re: Alternator belt tensioner + Alternator clutch pulley - time and money?
    Mar 2010
    County Durham. England
    What year car is it ,on my 2003 1.9 i was able to change belt , tensioner and alt pulley without removing the front end.
  4. Re: Alternator belt tensioner + Alternator clutch pulley - time and money?
    Dec 2012
    Peterborough
    Thanks early 2002
  5. Re: Alternator belt tensioner + Alternator clutch pulley - time and money?
    Aug 2011
    Meath
    You CAN do it with the lock carrier in place but it's far from easy especially if you're inexperienced
    Quote Originally Posted by A4 Les View Post
  6. Re: Alternator belt tensioner + Alternator clutch pulley - time and money?
    Jul 2011
    manchester
    Depending on how much knowledge you have,the alternater pulley on this engine is not too difficult.You need a reasonable tool set with a selection of torque drives,ie,45 50 short and long.A pulley removal kit,some decent sockets ring and offset spanners.Cost of the pulley is about £50
  7. Re: Alternator belt tensioner + Alternator clutch pulley - time and money?
    Aug 2011
    Meath
    You need to take off the viscous fan to get at the tensioner, plus it's still tight to change the belt, plenty of potential for skinned knuckles and mistakes due to frustration, it's not hard to put it in the service position anyway
  8. Re: Alternator belt tensioner + Alternator clutch pulley - time and money?
    Dec 2012
    Peterborough
    Thanks for the advice, I'm going to pay a garage to do this work for me asap - probably at the same time as a cambelt and waterpump change.
  1. Replies: 4
    Last Post: 04-01-2013, 03:51 PM
  2. A4 B6 1.8T Quattro Avant - Alternator Tensioner Pulley
    By dvoodoo in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-12-2012, 09:53 AM
  3. Replies: 6
    Last Post: 25-10-2011, 06:36 PM
  4. alternator fault, pulley or tensioner ?
    By jemthetaxi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-01-2010, 07:41 PM
  5. Kinda urgent - replacing belt tensioner, alternator pulley, and belt.
    By farmamick in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-03-2009, 05:00 PM
