Thread: Coolant temperature sensor
  1. Coolant temperature sensor
    Mar 2009
    Newton Swansea
    A bit more expense Scanner flagged up coolant temperature sensor fault seems to affect other things including throttle response sensor replaced & other fault codes gone throttle response much smoother but the costs add up £33 diagnostic (I'd already done my own) £30 labour £33 for new sensor & seal plus VAT of course. £123 all in. Well at least it drives better may be better fuel consumption as well.
  2. Re: Coolant temperature sensor
    Aug 2011
    Meath
    Still not bad tho
  3. Re: Coolant temperature sensor
    Mar 2009
    Newton Swansea
    Yes no real complaint it saved me the hassle I'm getting too old to spend time in the freezing cold with my head buried under the bonnet.
  4. Re: Coolant temperature sensor
    Aug 2011
    Meath
    On the other hand if you had bought VCDS you'd have saved a third of the price you paid for it on that one job
  5. Re: Coolant temperature sensor
    Mar 2009
    Newton Swansea
    Quote Originally Posted by Doctle Odd View Post
    Very true but I had already diagnosed it with my Autel VAGCOM scanner but the garage wanted to check with their unit if I had done the job myself I could have saved 2/3rds of the job so I paid for being a lazy old git!
  1. Temperature coolant sensor?
    By garyizme in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-12-2012, 12:19 AM
  2. Coolant Temperature Sensor
    By hod in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-07-2010, 05:48 PM
  3. Question Coolant temperature sensor
    By Adam A41.8T in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-07-2009, 10:26 AM
  4. Question Coolant temperature sensor
    By animal in forum Polo - Derby - Lupo - Fox
    Last Post: 02-01-2009, 11:18 PM
  5. Coolant Temperature Sensor or something else?
    By Tony Elphick in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-05-2008, 09:44 AM
