Thread: 2007 Jetta - Aerial connection for aftermarket radio
Results 1 to 10 of 11
  1. 2007 Jetta - Aerial connection for aftermarket radio
    Apr 2007
    Hello all,
    I'm hoping someone can help...
    I recently fitted a new double DIN radio into my Jetta. I bought all the necessary wiring adaptors including the one for the aerial.
    The new radio works, however FM is now suffering from poor reception on certain stations, and is picking up slight interference from the windscreen washer. Earth connection seems to be OK though.
    The aftermarket aerial adaptor has a blue wire, which I presume can be connected to the 'powered antenna' wire on the back of the radio? Does the Jetta have a powered antenna, and thus needs the blue wires connecting?
    When I removed the original radio, there was no obvious power connection to the antenna, just the standard VW connection, which may be powered?
    Any help greatly appreciated.
  2. Re: 2007 Jetta - Aerial connection for aftermarket radio
    Aug 2011
    Meath
    The aerial is powered by the factory radio you need to bring power to the blue wire for it to work properly
  3. Re: 2007 Jetta - Aerial connection for aftermarket radio
    Apr 2007
    Thanks for the reply.
    So, in simple terms what I need to do is supply power to the blue wire that is on the aerial adaptor, rather than the blue wire coming out of the back of the radio?
    Second question (and sorry for seeming rather dumb), where do I take a power supply from? All the wires in the car's loom appear to be connected to something in the ISO harness, the only two that don't seem to be doing anything are two very, very thin brown wires, and I have no idea what they are?!
  4. Re: 2007 Jetta - Aerial connection for aftermarket radio
    Aug 2011
    Meath
    Don't supply power to the blue wire coming from the stereo it's for an electric aerial, I think. It should be live when the ignition is switched on. You can wire your aerial back to the fuse board so it comes on when the ignition comes on or you can splice it into the live wire coming to your stereo (not the memory wire) if you're feeling particularly lazy use a scotchlock or you can buy the loom adapter from a well known auction site
  5. Re: 2007 Jetta - Aerial connection for aftermarket radio
    Apr 2007
    Thankyou once again! I think I'll splice it into the live wire coming into the radio. Hopefully that'll solve the problem!
  6. Re: 2007 Jetta - Aerial connection for aftermarket radio
    Apr 2007
    Update....I joined the blue wire from the aerial adaptor to the ignition live, and it did amplify the signal, but reception is still poor when on the move.
    The car has two aerial wires. Does it matter which one I connect to the aerial adaptor? Why does the car have two connections anyway? I have tried them both and can't pick up MW at all.
    I think I'll try joining the blue wire out of the radio into the ignition live too. It seems to be the only thing left to try!
  7. Re: 2007 Jetta - Aerial connection for aftermarket radio
    Mar 2012
    Essex
    I think you might need something like this
    Dual FAKRA to Male Aerial Adaptor for VW Golf MK5/Plus 04 to 07 | eBay
    read about this on gtimk5 forum.
  8. Re: 2007 Jetta - Aerial connection for aftermarket radio
    Apr 2007
    Thankyou!
    I have ordered a dual one with the built in amplifier.
    Certainly answers the question about which of the two aerial leads I need to use!
  9. Re: 2007 Jetta - Aerial connection for aftermarket radio
    Apr 2007
    Dual aerial adaptor fitted, and the problem still persists, although I can now receive MW.
    Everything is fine until I turn the key a notch in the ignition, and when other electrical systems on the car become live, the signal on the radio weakens. If I then remove the key from the ignition, the radio signal remains weakened, until the car's electrics shut down (approx 15 secs) and the signal becomes fine again on the radio.
    With the engine started, and the car in motion, on all but the strongest of stations, there is regular interference, such as when a wagon pulls up next to me, or when going down a hill etc etc. Also, there's a slight crackle when using the windscreen washer, which suggests an earth problem, but all the wiring appears to be fine.
    Can anyone offer any further help before I end up having to pay someone a small fortune to fix this?!
  10. Re: 2007 Jetta - Aerial connection for aftermarket radio
    Aug 2011
    Meath
    Only thing left is the aerial itself they get water into the electrics
  1. Aerial connection
    By audisingh in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-05-2011, 04:50 PM
  2. Aerial connection - where is it ??
    By dandam in forum In Car Entertainment
    Last Post: 17-03-2010, 09:09 AM
  3. Aerial Connection - any idea where it is ??
    By dandam in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 12-03-2010, 06:38 PM
  4. passat tdi - aftermarket cd/mp3 player - amplified aerial
    By hoffmeister in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-09-2009, 05:57 PM
  5. Question Concert aerial connection?
    By jon_iz in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 12-01-2009, 10:09 PM
