Thread: Rear brakes
  1. Rear brakes
    Was hoping to replace rear discs and pads on the cc has anybody done this themselves ? What I would like to know is can you remove the rear discs without taking the caliper carriers off and how to wind back the caliper pistons have been told you can do without vcds any advise welcomed cheers
  2. Re: Rear brakes
    UK Ex-pat now in Australia
    Do not attempt to wind back the piston without using a diagnostic tool - it can cause damage to the electric motors and after work is done the system needs to learn the new position in order to work correctly.
    Had MKV GTI, Now Ford Falcon
  3. Re: Rear brakes
    Norfolk
    Quote Originally Posted by muddybuggy View Post
    See here: CHANGING B6 REAR BRAKE PADS WITHOUT VCDS - PASSAT
  1. Question Rear brakes
    By SVstu in forum 80 - 90
    Last Post: 23-06-2010, 11:07 AM
  2. Rear brakes - need help
    By vroooOOOM in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-06-2010, 04:38 PM
  3. rear brakes
    By superkel in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 06-11-2009, 05:16 PM
  4. Please Help A3 Rear brakes
    By Rarebit in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 06-09-2009, 06:35 PM
  5. Rear brakes
    By britaxcooper in forum Golf MK3 - 1993 - 1999
    Last Post: 26-12-2007, 11:13 AM
