Thread: Intake Manifold Flap Position Sensor (Bank 1)
  1. Intake Manifold Flap Position Sensor (Bank 1)
    Jan 2013
    Scotland
    11 Post(s)
    So its been about 2 weeks since I cleared all my faults codes, and today I rescanned. Looks like I got some problems huh? What prompted me to scan was yesterday I noticed the emission management system light had come on, and remained on, worried about my dpf, I googled a little for some info. Some advice said to drive for about 10 mins in 4th gear about 50mph, basically above 2krevs. So I done this tonight, and the intitally I wasn’t convinced this helped. But I popped into my mums imediitally after this test drive for my dinner, and when I came back ouot, the light come on initially as I belove it should on ignition, and then went out, so maybe I did clear something out after all???
    Anyway, I came home and scanned with my vagcom, and this was my results…..
    Not sure if this is realted, or even an issue but I I feel my fuel drains at what feels like an alarming rate….related at all?
    Code:
    Thursday,14,February,2013,19:31:48:32264VCDS Version: Release 11.11.3
    Data version: 20120401
    Chassis Type: 8T0
    Scan: 01 03 05 08 09 15 16 17 19 42 46 47 52 53 55 56 62 72
    VIN: xxx    Mileage: 96980km/60260miles
    01-Engine -- Status: Malfunction 0010
    05-Acc/Start Auth. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    Address 01: Engine (J623-CCWA)       Labels: 059-907-401-CAP.clb
       Part No SW: 8K0 907 401 C    HW: 8K1 907 401 A
       Component: 3.0TDI EDC17  H01 0002
       Revision: 15H01---
       Coding: 0104002C180F0118
       Shop #: WSC 06325 123 12345
       ASAM Dataset: EV_ECM30TDI8K0907401C A01005
       ROD: EV_ECM30TDI8K0907401C.rod
       VCID: 2B5F1975421E111
    1 Fault Found:
    7156 - Intake Manifold Flap Position Sensor (Bank 1)
              P2015 00 [040] - Implausible Signal
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 2
                        Fault Frequency: 8
                        Mileage: 96890 km
                        Date: 2013.02.13
                        Time: 07:39:11
    Readiness: 0 1 0 0 0
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
       Part No SW: 8K0 907 379 AB    HW: 8K0 907 379 AB
       Component: ESP8 quattro  H04 0060
       Revision: --------    Serial number: --------------
       Coding: 1B0500
       Shop #: WSC 06325 000 00000
       VCID: 79F3F33DF0C2731
    No fault code found.
    Address 05: Acc/Start Auth. (J393)       Labels: 8K0-907-064-05.clb
       Part No SW: 8K0 907 064 C    HW: 8K0 907 064 C
       Component: BCM2 1.1      H70 0134
       Revision: 00002001
       Coding: 031100
       VCID: 30650E196338729
       Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
       Component: FBSAUDIB8 IDG  H37 0060
       Subsystem 2 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
       Component: ELVAUDIB8  H35 0039
    Address 08: Auto HVAC (J255)       Labels: Redir Fail!
       Part No SW: 8T2 820 043 S    HW: 8T2 820 043 S
       Component: KLIMA 3 ZONEN H06 0140
       Revision: D0000000    Serial number: 0127.06.080677
       Coding: 36040000
       VCID: 428154D1DD94F09
    Address 09: Cent. Elect. (J519)       Labels: 8K0-907-063.clb
       Part No SW: 8K0 907 063 C    HW: 8K0 907 063 C
       Component: BCM1 1.0      H22 0253
       Revision: 04022001    Serial number: 00000000074852
       Coding: 260050914034AF010001000000001D0D001D030800010141000000
       VCID: 2F670D657E066D1
       Subsystem 1 - Part No SW: 8K2 955 119     HW: 8T2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 010708  H05 0060
       Coding: 00FD11
       Subsystem 2 - Part No SW: 8K0 955 559     HW: 8K0 955 559   Labels: 8K0-955-559.CLB
       Component: RLS  H04 0003
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
       Component: E1 - LDS  H07 0070
    Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
       Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
       Component: AirbagVW-AU10 H26 0410
       Serial number: 0038JD17358O
       Coding: 30363434363030303030554A3052384B3053
       ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
       ROD: EV_AirbaECUVWAUDI010_AU48.rod
       VCID: 3C7D2A29B770869
       Crash sensor for side airbag; driver side:
       Serial number: 6334MSME2A640771A
       Crash sensor for side airbag; passenger side:
       Serial number: 6344MSME3B32197CM
       Crash sensor for side airbag; rear driver side:
       Serial number: 6352QSME7D69393F%
       Crash sensor for side airbag; rear passenger side:
       Serial number: 6362QSME7B2C2001D
       Crash sensor for front airbag; driver side:
       Serial number: 63732SME6A28441D4
       Crash sensor for front airbag; passenger side:
       Serial number: 63832SME72712077X
    Address 16: Steering wheel (J527)       Labels: 8K0-953-568.clb
       Part No SW: 8K0 953 568 F    HW: 8K0 953 568 F
       Component: Lenks.Modul   H12 0013
       Revision: --------    Serial number: 90315HG10008P
       Coding: 000016
       VCID: 3D7B272DA46A8F1
       Component: E221 - MFL  H02 0003
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
       Part No SW: 8K0 920 980 B    HW: 8K0 920 980 B
       Component: KOMBIINSTR.   H16 0221
       Revision: 00200000    Serial number: 99572X478
       Coding: 2305090002002600010000
       VCID: 31630B1D68327B1
    Address 19: CAN Gateway (J533)       Labels: 8T0-907-468.clb
       Part No SW: 8T0 907 468 H    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0091
       Revision: GB102039    Serial number: 3900G0862280E4
       Coding: 000303
       VCID: 468948C1F1BCCC9
       Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
       Component: J367-BDM  H04 0150
    Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
       Part No SW: 8K0 959 793 C    HW: 8K0 959 793 A
       Component: TSG FA        H10 0170
       Revision:             Serial number: 0000007363902
       Coding: 011002204001410001
       VCID: 40855ED9D398E29
    Address 46: Central Conv. (J393)       Labels: 8K0-907-064-46.clb
       Revision: 00002001    Serial number: 0112724652
       Coding: 011B062200390440002001
       Subsystem 1 - Part No: 8K0 951 177
       Component: DWA-Sensor  H02 0040
       Subsystem 2 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H03 1301
    2 Faults Found:
    02616 - Fuel Tank Cap; Unlock
                009 - Open or Short to Ground
                 Freeze Frame:
                        Fault Status: 01101001
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 24
                        Mileage: 96304 km
                        Time Indication: 0
                        Date: 2013.02.01
                        Time: 21:43:41
    02615 - Fuel Tank Cap; Lock
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 24
                        Mileage: 96304 km
                        Time Indication: 0
                        Date: 2013.02.01
                        Time: 21:43:48
    Address 47: Sound System (J525)       Labels: 8T0-035-223-ASC.clb
       Part No SW: 8T0 035 223 AB    HW: 8T0 035 223
       Component: DSP STD       H07 0220
       Revision: S1900000
       Coding: 0203010101
       VCID: 6ED9D061B98C249
    Address 52: Door Elect, Pass. (J387)       Labels: 8K0-959-792.clb
       Part No SW: 8K0 959 792 C    HW: 8K0 959 792 A
       Component: TSG BF        H10 0170
       Revision:             Serial number: 0000007388958
       VCID: 3F875D25AE669D1
    Address 53: Parking Brake (J540)       Labels: 8K0-907-801.clb
       Part No SW: 8K0 907 801 H    HW: 8K0 907 801 H
       Component: EPB Audi B8   H09 0100
       Revision: 00000003    Serial number: 10000000350688
       Shop #: WSC 00000 000 00000
       VCID: 346D020997204E9
    Address 55: Xenon Range        Labels: 8K0-907-357.clb
       Part No: 8K0 907 357 B
       Component: Dynamische LWR  H01 0030
       Revision: 00000001    Serial number:
       Coding: 0000004
       Shop #: WSC 06324 000 00000
       VCID: 346D020957204E9
    Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
       Part No SW: 8T2 035 186 C    HW: 8T2 035 186 C
       Component: Concert3      H02 0210
       Revision: 00000004    Serial number: AUZ5Z6H1085064
       Coding: 0502008001010D000359070000
       VCID: 387536398B48AA9
       Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
       Component: Display
    Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
       Part No SW: 8K0 959 795 A    HW: 8K0 959 795 A
       Component: TSG HL        H06 0170
       Revision:             Serial number: 0000100106484
       Coding: 010002204001210001
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
       Part No SW: 8K0 959 794 A    HW: 8K0 959 795 A
       Component: TSG HR        H06 0170
       Revision:             Serial number: 0000100106115
    End   ---------------------------------------------------------------------
    Audi A6 3.0 BiTDI Black Edition
  2. Re: Intake Manifold Flap Position Sensor (Bank 1)
    Jan 2013
    Scotland
    11 Post(s)
    anyone? is this a sensors that can be cleaned?
  3. Re: Intake Manifold Flap Position Sensor (Bank 1)
    Jul 2012
    Derby
    Does your glow plug light flicker sometimes when you are moving along? I changed this on mine and it cleared the fault and flashing glow plug light issue, very easy part to fit and you can get an aftermarket one that is manufactured by the same company as the oem one.
    hope this helps
  4. Re: Intake Manifold Flap Position Sensor (Bank 1)
    Jan 2013
    Scotland
    11 Post(s)
    hi, no it doesnt!! wondering if i need to reaplce the whoel manifold, did you get he exact same fault, i.e. 2015?
  5. Re: Intake Manifold Flap Position Sensor (Bank 1)
    May 2012
    West London
    Have you managed to sort this prob?
    If not, do you have a loss power like imp mode? If so, check your EGR valve, it may be gunked up, give it a good clean. I have a thread on it on the A4-B7 Forum.
    If you don't have limp mode, try cleaning the MAF using compressed air from a can and check the rubber vacuum hoses connected to the flap actuator.
  6. Re: Intake Manifold Flap Position Sensor (Bank 1)
    Jan 2013
    Scotland
    11 Post(s)
    hi, not yet, ordered a new connecting rod from audi for £8.70 as i understand this can often be the issue. i'll fit this tomorrow and report back in a few days, failing that, will try your suggestion. Thanks
  7. Re: Intake Manifold Flap Position Sensor (Bank 1)
    Jan 2013
    Scotland
    11 Post(s)
    so me and my mate had a look this morning, and the right side manifold, i.e. bank 1 flap was defo jammed. the left side was oscillating with engine idle, presumably to compensate for the loss of the other?? anyway, my pal gave the right one a little tug with long nose pliers, and it pulled it free from the jam. and appeared to operate properly. the left bank then stop oscillating too. both actuators moved as expected when engine was revved etc.
    so, do you think the manifold is just dirty, and the flap is jamming? motor seems to work ok once it was free. bearing in mind this is an intermintant fault, therfore i pressume it stick sometimes, then other times it manages to free its self.
    Thoughts?
  1. Please Help 004120 - Intake Manifold Runner (Bank 2): Lower limit not reached
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-05-2017, 06:45 PM
  2. Intake manifold flap
    By john-mandy in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-12-2010, 11:48 PM
  3. Intake Manifold Flap (V157)
    By SebastianTDI140 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-06-2010, 08:07 PM
  4. Motor for intake manifold flap
    By stephen k in forum Golf MK4 - 1999 - 2004
    Last Post: 31-05-2009, 05:47 PM
  5. Motor Intake Manifold Flap
    By daveaustin in forum Archive posts
    Last Post: 06-12-2007, 04:39 PM
