Thread: Mirror dip on reverse issue?
Results 1 to 10 of 18
  1. Mirror dip on reverse issue?
    Wuffles Guest
    As jbanfie kindly enabled this option for me I attempted to tell the story of an E46 3 series I owned that used to knacker up the final position of the mirror after every dip. Guess what my A6 does now after some dips. Are there grave instructions for use? Should I make sure the mirror has returned to the undipped position before turning off the vehicle for example?
    Incidentally, BMW always blamed the problem on Uplands Car Radio who had replaced the dire standard fit speakers, whereas Uplands always blamed BMW, then I sold it.
  2. Re: Mirror dip on reverse issue?
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Mine occasionally returns to a position too high for normal use. There doesn't seem to be any pattern to it, though. Maybe one in 20 times I have to reset the mirror position afterwards. It certainly beats having to manually lower and raise the mirror every time I reverse, so I'm happy to live with it.
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  3. Re: Mirror dip on reverse issue?
    Wuffles Guest
    Does it happen to those that have paid for the option do you know?
  4. Re: Mirror dip on reverse issue?
    Nov 2009
    46 Post(s)
    If you have memory seats and memory mirros it will return to the position set as it remembers the position.
  5. Re: Mirror dip on reverse issue?
    May 2009
    69 Post(s)
    If you have memory seats and memory mirrors it will return to the position set as it remembers the position.
    It does on my car too, 95% of the time, but just occasionally it seems to throw a wobbler and reset to a random position. I keep meaning to re-engage reverse at that point and let the mirror dip again, then see if it returns to the normal position or the "new" position it adopted, but I haven't remembered to do it. Sigh. I'm getting to be a senile muppet these days!
    MF.
  6. Re: Mirror dip on reverse issue?
    Wuffles Guest
    It happened on the BMW possibly because we had memory seats. It seemed to highlight the problem more anyway.
    So, with some experimentation I can get it to screw up nearly every time, but bad light stopped play for me tonight. I'll investigate further over the weekend. It must be the way/order I do things on the car that makes it happen otherwise others would surely be asking the same question.
  7. Re: Mirror dip on reverse issue?
    Aug 2009
    Crewe
    Wuffles- what is vehicle in motion. I understand the mirror dip and needle sweep I am going to do those when mine arrives on the 1st March.
  8. Re: Mirror dip on reverse issue?
    Wuffles Guest
    Enables video playback over 2mph or whatever the restriction is by default. Handy for me anyway.
  1. Nearside electric folding mirror doesn't dip
    By bertj in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 03-08-2012, 07:32 PM
  2. Dipping door mirror on reverse
    By piotrek in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-08-2011, 06:24 PM
  3. Please Help auto dip mirror suicide... grrrrrrrr
    By shazzam in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-03-2010, 10:53 PM
  4. Auto Dip Rear View Mirror
    By WesleyP in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-06-2009, 10:20 AM
  5. S3 passenger mirror dip when "reverse" is engaged
    By steveR32 in forum Audi A3 - Archive Topics
    Last Post: 15-02-2008, 09:12 AM
