Thread: Expensive Day
  1. Expensive Day
    Dec 2009
    14 Post(s)
    I retract my previous thread ultra-reliable
    What a day. Remote on the car has decided to give up the ghost. Could not open the car with the plastic key either. And to make matters worse I have lost or should that be the wife has put the spare key somewhere very safe.
    The AA guy has towed my car to the local VW dealer who has gained entry. They have got the spare key working in the lock with the aid of WD40. They have tried the battery reset also tried to get the key to talk but the key is dead.
    New key + coding £170.00
    Also, they asked if I was aware that the DMF needed replacing. Different story to the other VW dealer. They have said £1200 to replace. VW won’t offer a good will. What should I do?
    I won’t be using VW just my faithful independent.
    Help & advise greatly appreciated,
    Thanks, Rappy.
  2. Re: Expensive Day
    Jan 2013
    Limerick, Ireland
    Were you aware that the DMF needed replacing yourself?...Usually you can tell if the DMF is going bad by placing your foot on the clutch when the engine is on and the car is idle...if the clutch pedal is vibrating this is one of the signs. Also when you start up the car the engine should shake more violently that usual and you might here the DMF "slipping" ever now and then while the engine is running. I have these signs at the moment but I'm not worrying about it yet, my previous car was a mondeo which I had to replace the DMF in but the problems were alot more noticeable than in the passat...I'd imagine my passat DMF has gotten as bad yet as in my Mondeo. Also if you do have to get it done your better off sourcing the parts yourself from the likes of ebay where you'll get a DMF, clutch kit and release bearing and getting your local mechanic to fix it...should work out at less than have the price
    0 0 1
  3. Re: Expensive Day
    Dec 2009
    14 Post(s)
    Quote Originally Posted by Dave_Bounce View Post
    Thanks for your reply. A bit hard with a dsg box :-):-):-).
  4. Re: Expensive Day
    Dec 2009
    14 Post(s)
    I can get in done for £600 :-). No issues other than a rattle in park or neutral.
  5. Re: Expensive Day
    Up North
    Well, at least it's not the DSG like you were worrying about. Look on the bright side, you've saved the top side of £2k.
    Driving - Shiny new E350 Estate.. Just Arrived - Aggh! a C-Max. What have I done?
    Just Gone - 2008 Passat 2.0CR TDi DSG Estate + toys, 2007 Golf GTI
    Once, cars were simple and I was smart. Now things are the other way around.
  1. Hello to all....hope this is not expensive!!
    By Booky16v in forum New Member Introductions
    Last Post: 05-07-2010, 01:13 PM
  2. Whats your best day trip?? Im off to Dublin for the day...
    Last Post: 21-10-2008, 12:48 PM
  3. Electrical fault(ref"expensive day")
    By Dainty in forum Touran - Sharan - Caravelle
    Last Post: 27-03-2008, 12:21 AM
  4. Expensive day
    Last Post: 03-03-2008, 10:16 PM
