Thread: 2 engine coolant temperature sensors A4 B6 2.0
  1. 2 engine coolant temperature sensors A4 B6 2.0
    Jan 2013
    Newry, Northern Ireland
    I have a 2002 Audi A4 2.0 petrol. The coolant temperature gauge doesnt move at all and the radiator fan is constantly on. The dealer told me the car has 2 coolant temperature sensors, and I would have to replace both of them. One is a green 4-pin sensor and the other is a grey 2-pin sensor. I have located and replaced the green ect sensor but the temperature gauge still does not move and the radtiator fan is still constantly on. I cannot find where the grey 2-pin sensor goes. Can anyone help me locate this please?
  2. Re: 2 engine coolant temperature sensors A4 B6 2.0
    Jan 2011
    derby UK
    The green two pin sensor is dual sensor. It reads temp. for dash and ECU. Check with VCDS if it is sending correct temp to ECU. I've replaced mine in September only to find out at the weekend that it was not sending correct temp to ECU.
  3. Re: 2 engine coolant temperature sensors A4 B6 2.0
    Sep 2011
    Shannon, Ireland
    Hi. Grey 2 pin sensor located on near side of radiator, lower flange. If you lay down and look from near side wheel you will see it pointing downwards from the flange. I was able to change it in situ without even jacking the front of car. I can post a picture if need be
    2001 Audi A4 2.0 20V
    1995 VW Polo 1.05-sold
    Mod's so far: cruise control and DIS retrofitted, two cup holders in dash
    Mod's to come: ESP switch and card holder relocation, color DIS, extra lighting
  4. Re: 2 engine coolant temperature sensors A4 B6 2.0
    Mar 2013
    norfolk
    did you get it fixed? my car has same issue,but sensors didnt fix it
  1. Please Help Engine Coolant Temperature Sensor 2.4 V6
    By plugin in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-10-2012, 07:31 PM
  2. Please Help A4 1.9TDI - Faulty Engine Coolant Temperature Gauge
    By dezzy1908 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-06-2012, 08:24 PM
  3. Rapid coolant loss and engine temperature dropping!
    By Fork86 in forum Golf MK4 - 1999 - 2004
    Last Post: 24-08-2009, 07:25 PM
  4. 2004 A6 1.9TDi Engine Coolant Temperature Sensor
    By tiptop in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-05-2008, 02:39 PM
  5. Low engine coolant temperature, which coolant to use
    By rhencullen1989 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-12-2007, 11:35 AM
