Thread: faulty drivers door console, windows/mirror/door lock not working
  1. faulty drivers door console, windows/mirror/door lock not working
    Jan 2013
    thornton cleveleys
    hi
    I own a 2005 alhambra 19 tdi sx with an electrical problem in my drivers door, when i lock the door with the keyfob all the doors lock except the drivers, i can lock it manually and again when i use the keyfob to unlock the doors they all unlock except the drivers which i can unlock manually.
    Now inside the car none of the windows open via the drivers arm rest control but the passanger windows all work independently, my wing mirrors also wont adjust of retract inwards, I have checked the fuses and they are all ok. Any help woud be greatly appreciated, thanks.
  2. Re: faulty drivers door console, windows/mirror/door lock not working
    Southern County Softy
    20 Post(s)
    Check the loom between the drivers door and the A pillar for broken wires.
    ....If only I was as smart as this bloody phone
    A4 2.5 tdi QS (mapped)
  3. Re: faulty drivers door console, windows/mirror/door lock not working
    boustie Guest
    would agree with above, try wiggling that grommet and see if it starts working again if so then loom is split
  4. Re: faulty drivers door console, windows/mirror/door lock not working
    Sep 2010
    Wirral
    As above been there seen it done it, all doors and tail gate will go eventually usually the thicker wires. You need tool to extract old wires from multi socket and put new ones in and then solder further in door, don't repair at break theres not enough flex and wont last 5 minutes.
  1. b5 door lock faulty?
    By paulos130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-06-2011, 10:19 PM
  2. Electric door mirror adjustment faulty?
    By illestjt in forum Golf MK6 - 2009 - 2013
    Last Post: 10-03-2010, 02:48 PM
  3. A6 Drivers Door Lock Sticking and door occasionally not opening
    By CliffA6 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-02-2010, 10:53 PM
  4. 1997 1.4 5 door VW Polo Door Lock not working
    By MathewRB in forum Polo - Derby - Lupo - Fox
    Last Post: 03-01-2010, 12:01 PM
  5. Faulty vw heated door mirror
    By jmoon in forum Golf MK5 - 2004 - 2009
    Last Post: 13-02-2008, 04:12 PM
