Thread: Oil Leak From Side Of Engine
Results 1 to 8 of 8
  1. Oil Leak From Side Of Engine
    Dec 2009
    Basildon, UK
    While driving this morning I noticed smoke coming from the bonnet, I quickly pulled over and lifted the bonnet to find oil pouring out from the side of the engine. The source of the leak is a small rubber plug of some sort that goes into the side of the engine block near the distributor cap, I am not sure what this is?
    I was hoping somebody can tell me what it is and whether it can be easily replaced or is it a job for a mechanic. Any help or advice would be appreciated.
    My car is a 1997 Mk3 Golf 1.6 GL (AFT Engine)
  2. Re: Oil Leak From Side Of Engine
    Aug 2011
    Meath
    Can you add a photograph to your post?
  3. Re: Oil Leak From Side Of Engine
    Dec 2009
    Basildon, UK
    Here is a link to a picture, it's the rubber connector with the wire coming out of it with tissue under it.
    https://www.4shared.com/photo/WVvwo7...f_Mk3_pic.html
  4. Re: Oil Leak From Side Of Engine
    7 Post(s)
    Oil pressure sender is naffed
  5. Re: Oil Leak From Side Of Engine
    Dec 2009
    Basildon, UK
    Now I know what it is, is it difficult to replace and roughly how much does a replacement cost.
  6. Re: Oil Leak From Side Of Engine
    Aug 2011
    Meath
    Col is correct they are easy to replace and genuine ones are less than a tenner
  7. Re: Oil Leak From Side Of Engine
    Dec 2009
    Basildon, UK
    Thanks to both of you for your help, I feared it was going to be a costly repair. I will order one tomorrow and get it replaced. Thanks again..
  8. Re: Oil Leak From Side Of Engine
    Dec 2009
    Basildon, UK
    I changed the Oil Pressure sender yesterday, no problems at all..10 minutes is all it took. Unplug the wire, unscrew (anti-clockwise) and replace. a tip to anyone who is going to change this part, you will need a 24mm deep socket or ring spanner...you will not do it with a normal socket due to the shape of the part, I had to borrow one from a friend.
    I have a Haynes manual but could not see any reference to a Oil Pressure Sender in there. Is it under a different name in manual??
    Once again thanks to BigCol and Doctle Odd for there knowledge and help.
  1. Oil leak from driver side
    By Abuabida in forum Bora - 1998 - 2005
    Last Post: 07-04-2017, 08:51 PM
  2. Oil leak from rear of engine (2.8 ACK Engine)
    By stoocake in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-01-2011, 09:35 PM
  3. Off-side front oil leak
    By TEEMMERT in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-05-2009, 07:50 PM
  4. Replies: 2
    Last Post: 02-07-2008, 07:50 PM
  5. Engine oil leak
    By tel7448 in forum Passat - Archive Topics
    Last Post: 01-04-2007, 10:30 AM
