Thread: Coolant temp sensor location?
Results 1 to 10 of 18
  1. Coolant temp sensor location?
    Feb 2009
    Glasgow UK
    Hi all,
    I'm considering replacing my coolant temp sensor, can anyone help with location??
    I've looked and looked and struggle to find info so any help is appreciated.
    As stated in previous posts, car seems to have lost some of its power, almost as if its struggling to breathe and fuel consumption has
    went from pretty good to terrible recently. At 99k and with no CEL no codes etc, car serviced regularly and looked after I'm leaning towards
    the MAF and coolant sensor.
    Hope to hear & thanks in advance
  2. Re: Coolant sensor location?
    Oct 2005
    ElsaWeb - Parts of cooling system
    Back left of the block as you stand at the grille
  3. Re: Coolant temp sensor location?
    PM me and I send you the drawing. Can you read .mdi files. Regards Peter
  4. Re: Coolant temp sensor location?
    Feb 2009
    Glasgow UK
    Peter D - Extremely helpful as always, thanks very much.
    Sam - help from an unexpected quarter and very quick too, much appreciated
  5. Re: Coolant temp sensor location?
    Note. On this model the sensor is a 2 pin device and if the temp gauge indicates 88/90 degrees then the sensor is working. The signal in connected directly to the 'Diesel direct injection system control unit' and a signal sent from there to the gauge. If the Temp is correct then you need to test the Fuel Temperature Sensor. A diagnostic check would be in order as it can check both senors and the MAF by using live data. Regards Peter
  6. Re: Coolant temp sensor location?
    I need your email address to send the drawing if you still require it. Regards Peter
  7. Re: Coolant temp sensor location?
    Feb 2009
    Glasgow UK
    Hi Peter, thanks but Sam has already provided the info in the post prior.......your offer / help appreciated as always.
    Looking at the schematic then checking the engine itself, the coolant sensor looks like a bear to change?
    God you'd think they'd make these kind of items a little easier to change as they are known to fail.
    Any words of wisdom on the replacement method that can save hassle / grief most welcome.....lol
  8. Re: Coolant temp sensor location?
    Sep 2011
    Lurking over a keyboard ...
    Hi Jim,
    Check your email sent you a file with P/N's, diagram... may help you...
    I'm inclined to go with a live data scan like Peter D saying Jim...
    Like my EGR blockage was effecting air mass readings but not showing as a fault code...
    ATB
    Gup
    1 1 0
  9. Re: Coolant temp sensor location?
    Feb 2009
    Glasgow UK
    Gup, an absolute mine of information once again mate, thanks so much!
    You truly are one of the gentleman of the forum, great really informative posts ALWAYS long and indepth c/w with pictures and or videos.......An awesome member to have onboard VWAF
    I know that Peter and you are both right.....I know myself that I need a diagnostic run and am trying to diagnose myself prior to going in to the dealers next week, for a costly run on the diagnostics. I am a big fan of the dealers don't get me wrong, but like most people things are tight right now and if there's any way I can save £££ on diagnostics + fitting charges, I have to explore that option.
    I know that low on power and high fuel consumption can be attributed to a few things, and that the coolant sensor + MAF could have their part to play.....The Lambda sensor G39 is now also a possible culprit I guess?
    To be fair and rather than throw parts at it I need a live scan. Don't know if we have anyone with the kit and knowledge in the Glasgow area, I'll need to check.
    Failing that I have no option I guess but to wait and get it into the dealers as booked for next week.
    Thanks for your help guys, appreciated as always
    1 1 0
  10. Re: Coolant temp sensor location?
    Sep 2011
    No worries Jim, no bother for a top bloke like yourself ... your making me ...
    What about a VCDS scan from a member close to you?
  1. Please Help coolant temp sensor location
    By arman123 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-06-2011, 10:43 AM
  2. a3 coolant temp sensor location
    By woody650 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 17-04-2010, 12:34 PM
  3. Coolant Temp sensor location
    By Saturn in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-12-2009, 07:41 PM
  4. IAT (Intake air temp) and Coolant Temp sensor location
    By yep.its.jay in forum Audi A3 - Archive Topics
    Last Post: 16-03-2009, 10:33 PM
  5. A4 B6 1.8T coolant temp sensor location?
    By lwodrumm in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-12-2007, 05:41 PM
