Thread: Golf MK5 GT TDI 140BHP CLUTCH PROBLEMS!
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: Golf MK5 GT TDI 140BHP CLUTCH PROBLEMS!
    Sep 2020
    Staffordshire
    Quote Originally Posted by chris1391 View Post
    I Have recently purchased a MK5 Golf GT TDI 140BHP On a 2004 plate. It drives great however every so often the biting point is really low to the floor and occasionaly it doesnt go into 1st gear easily. Both these problems are very minor and arnt a big problem to me but do I need to prepare for huge bill coming my way? It has 105k on with Full Service history.
    All ideas appreciated...
    Have you tried bleeding the brakes as it might be same system as the clutch. If they separate them check clutch fluid and check no air in the system..
  2. Re: Golf MK5 GT TDI 140BHP CLUTCH PROBLEMS!
    Oct 2017
    London
    12 Post(s)
    Biting point low to the floor is annoying and can be the clutch itself. If bleeding doesn’t work and there’s no leaks then it’s gearbox out sadly.
  3. Re: Golf MK5 GT TDI 140BHP CLUTCH PROBLEMS!
    Oct 2022
    Ex13 5RG
    I have a mk 5 2.0 tdi 2003 with the same problem. My clutch is fine but it is tough to get in to 1st and reverse. I go to pull away and you lift the pedal up and it clonks in to gear
  4. Re: Golf MK5 GT TDI 140BHP CLUTCH PROBLEMS!
    1840 Post(s)
    Probably concentric release bearing failure
  1. fitting glow plugs mk5 golf 2.0 gt tdi 140bhp
    By willielavery in forum Golf MK5 - 2004 - 2009
    Last Post: 16-10-2016, 04:29 PM
  2. Question Golf Mk5 1.9 TDI Clutch Spring
    By Iananderson in forum Golf MK5 - 2004 - 2009
    Last Post: 15-04-2012, 08:59 PM
  3. Question Servicing on a MK5 VW Golf GT TDI 140Bhp
    By TonyDB in forum Golf MK5 - 2004 - 2009
    Last Post: 09-06-2010, 06:16 PM
  4. B7 Avant 2.0 TDI 140BHP Clutch
    By aelaes in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-05-2009, 08:54 PM
  5. Golf MK5 TDi 1.9 Clutch Problem
    By db1145 in forum Golf MK5 - 2004 - 2009
    Last Post: 15-02-2008, 09:11 AM
