Thread: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
Page 33 of 38 FirstFirst ... 233132333435 ... LastLast
Results 321 to 330 of 372
  1. Re: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
    Nov 2016
    Cardigan
    6 Post(s)
    Hey,
    I'm thinking torque converter . I agree, normally ZF boxes are pretty robust. I've been to one of their gearbox factories at their headquarters in Friedrichshafen for work, very impressive!
    RPM flutter / fluctuation was there before the oil/filter change and made no difference. Plus it only happens when the gearbox is engaged.
    Rowdy - you're not wrong but I'm pretty OCD about my cars and I watch the RPM needle moving around more than I watch the road - slight exaggeration but it is frustrating, distracting and could mean something bad down the line!
    I've bought two tubes of "Dr Tranny" on ebay and will pop those in when I get the chance, doubt it'll do much.
    Hi niedzial - awesome! From my googling it would suggest it's the TC although changing doesn't always cure. I'm more concerned that something catastrophic will happen to the GB whilst ferrying the family around, not cool. I don't know about yours but once up to temperature I see a marked improvement.
    My 50 mile, each way, commute, starts with 5 miles of 30mph and the needle fluctuates and finishes just off the M4 motorway where the needle is steady. Going the other way I'm straight onto the motorway for 20 miles, so 70mph, and I don't notice any RPM needle wobble.
    Look forward to your feedback, good luck!
  2. Re: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
    Jul 2015
    Staffs
    46 Post(s)
    Quote Originally Posted by Mintyjim View Post
    Hey,
    I wouldn't add any additive to the oil to be honest.
    I heard of this problem occurring before and other owners chasing it without any luck. Does it do it in D S and Tip?
    Ian
    A4 B6 Avant Nogaro Blue
  3. Re: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
    Nov 2016
    Cardigan
    6 Post(s)
    you're probably right!
    Good point. I'll check if it's the same in S and Tip, yes to D of course.
  4. Re: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
    8 Post(s)
    Had the same with mine, never failed on me even with plenty more miles etc. Tried oil change but never went.
    Landrover Discovery 4 3.0 SDV6 HSE
    A6 (C6)Quattro 3.0 tdi Avant Fully loaded Le Mans. Sold
    A6 (C5)Quattro 2.5 tdi(AKE) PP683's & Celtic Remap Sold
  5. Re: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
    Nov 2016
    Cardigan
    6 Post(s)
    Hi there, how'd you get on with ZF?
    Cheers,
    James
  6. Re: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
    May 2016
    London
    18 Post(s)
    So been to zf ... converted needs to be changes . Also as the converter dosent hold presure this has an effect on the rest of the tranny as the selenoids need to work harder to compensate . Once the gearbox is out and conventer changed they will test the rest
    Sent from my SM-G950F using Tapatalk
  7. Re: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
    Nov 2016
    Cardigan
    6 Post(s)
    Bloody hell, that sounds expensive! That would be about a third of what my car is worth. Where is the ZF site you took the car to?
  8. Re: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
    May 2016
    London
    18 Post(s)
    There is 2 that i found in uk after speakimg to ZF headoffice . Bristol transmitions and planet gears in peterborough . Both gavw me the same answer
    As to cost its a minimum £1.5k job
  9. Re: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
    Mar 2018
    GB
    Advice anyone please?
    My local indi just recently done a fluid change on my 2010 A6 with the ZF 6HP19a transmission. He used Febi Bilstein 34608 6HP fluid, and replaced around 8 litres. The box has developed a slip in 3rd gear. Is this the wrong oil? Would I need to replace with ZF lifeguard 6, as the oil that came out was yellow? Audi recommend the latest lifeguard 8 (green), but apparently an update is needed too.
    I'm at a loss and don't know what to do.
    Thanks.
    Sent from my SM-G935F using Tapatalk
  10. Re: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
    8 Post(s)
    The oil is correct as a lifeguard 6 alternative however, lots of talk that it would have lifeguard 8 on the later cars. It might be why you now have a slip if the wrong oil has been used.
  1. A6 TDi 2.7 Quattro Tiptronic - electrical gremlins
    By Slaine in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-04-2010, 10:13 AM
  2. Please Help A4 2.5 tdi quattro sport tiptronic problem
    By rts1275 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-01-2010, 01:23 AM
  3. Jerky Gearbox - A6 2.5 TDI Quattro Tiptronic.
    By jahgti1 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 10-11-2008, 12:57 AM
  4. audi a6 2.8 quattro tiptronic gearbox problem
    By kirky944 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-11-2008, 06:31 PM
  5. audi a6 2.8 quattro tiptronic gearbox problem
    By kirky944 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 01-11-2008, 06:18 PM
