Thread: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
Page 13 of 38 FirstFirst ... 3111213141523 ... LastLast
Results 121 to 130 of 372
  1. Re: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
    Nov 2012
    Somerset UK
    Perhaps this kit? They used this one on mine:
    ZF6HP19 Fluid Filter Change Kit - Bristol Transmissions Ltd
    They used the pentasin fluid on mine and no problems
    ZF Lifeguard 6, Shell M 1375.4,Transmission Fluid, ATF,
  2. Re: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
    Jan 2014
    Angus
    Quote Originally Posted by gianton View Post
    Which oil they used?
    There own oil. Doesnt have a number or a name, buts they said its pretty much the same as ZF lifeguard 6.
    Murray
  3. Re: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
    Sep 2012
    Bristol
    Hi guys, I may be trying to wake up a dead thread, but I've found a interesting web page with what looks like exact description of the OP original problem.
    AGCO Automotive Repair Service - Baton Rouge, LA - Detailed Auto Topics - What is Torque Converter Shudder
    Here the vibrations are reported as torque converter shudder with a very detailed description of possible cause and way to fix it. Worth reading.
    Interesting point is re-tightening the valve body bolts while doing the ATF change.
    I may give it a go, i.e. ask my indie to re-tighten the valve body when doing the next ATF change. As OP's car, mine had developed the same kind of shudder which was mended by ATF change. However, the shudder eventually came back after about 7-8000miles, not as bad as it used to be, so next ATF change is on the cards, this time with re-tightening the valve body bolts and replacing the ATF cooler pipes due to surface corrosion (just in case).
    Have a look at the web, see what you think.
    2 2 0
  4. Re: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
    Nov 2012
    Somerset UK
    Quote Originally Posted by funavant View Post
    Mine's had a fluid/filter change at 86k miles and is having another fluid change in few months, any idea what the torque settings should be?
  5. Re: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
    Sep 2012
    Bristol
    I am just checking ElsaWin copy on my computer, so give me few minutes.
  6. Re: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
    Sep 2012
    Bristol
    Here you are Mark:
    Tighten securing bolts -1- and -2- for mechatronic unit to 2 Nm.
    Then tighten retaining bolts to 8 Nm in specified sequence -1 ... 11-.
    That's what ElsaWin says about my car (A6 Avant LeMans, 3.0TDI, 2008).
    Last edited by Sam; 08-04-2014 at 11:20 AM. Reason: Removing ELSAWin images - Copyright material is NOT permitted.
  7. Re: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
    Oct 2005
    VW Audi Forum - "Copyright"
    I've had to remove the ESLAWin image from the above post.
    If you must share it, please do so off the forum. Petty I know, but I quite like VWAF and I want it to remain open and free for all.
  8. Re: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
    Nov 2012
    Somerset UK
    Appreciated Fun, pretty low torque then!
    Am guessing it's easy to access once tranny sump dropped?
  9. Re: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
    Sep 2012
    Bristol
    Mark, it should be accessible right after you drop the sump and remove the strainer.
    Sorry about the picture had to be removed,if you need it, PM me and I'll send it to you.
    I would just ask the guy working on my tranny to set the torque to 8Nm and go round the bolts and see what happens, if the bolts would turn at all. The idea is that the gasket perishes over time and may get thinner compared to when new, therefore not sealing properly and causing cross leak. If you think about it, it does make sense because when there is a small cross leak the tranny cannot apply enough pressure to the lock up clutch (when in low rpm) and that's where you can feel shudder.
    So re-tightening should make the mechatronic (valvebody) unit to sit tightly, preventing cross leak and allow to build up enough pressure for the lock up clutch.
    2 2 0
  10. Re: ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
    Nov 2013
    Vienna
    Hi all,
    Is it actually possible to do this job without raising the car on a lift? My Car a May 2005 3.0TDI Quattro tip avant, seems to be too low to get underneath it!
  1. A6 TDi 2.7 Quattro Tiptronic - electrical gremlins
    By Slaine in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-04-2010, 10:13 AM
  2. Please Help A4 2.5 tdi quattro sport tiptronic problem
    By rts1275 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-01-2010, 01:23 AM
  3. Jerky Gearbox - A6 2.5 TDI Quattro Tiptronic.
    By jahgti1 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 10-11-2008, 12:57 AM
  4. audi a6 2.8 quattro tiptronic gearbox problem
    By kirky944 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-11-2008, 06:31 PM
  5. audi a6 2.8 quattro tiptronic gearbox problem
    By kirky944 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 01-11-2008, 06:18 PM
