Re: Starting problems - clutch / DMF ???? –
17-01-2013,02:27 PM
Originally Posted by
xtremist
A question for the more knowledgeable people on here.
I have a A4 B8 with a 2 litre 143ps tdi engine and it’s becoming more and more temperamental to start. For the last few months, when you push the key in and depress the clutch to start the engine, it doesn’t always start. In the last few weeks it has started to tell me via the display on the dash to depress clutch to start.
The clutch itself appears to be fine and isn’t slipping. I think the DMF needs replacing as it’s become noisy and rattles when starting and tick over. If driving in 5th or 6th at about 1400RPM it vibrates.
Has the DMF got anything to do with it not starting, or is there something else which may cause this issue ? Don’t really want to spend circa £1000 for a new clutch and DMF and still have the problem.
Thanks in advance,
Does this post help:
2.0 tdi non start fault
Cheers!
MF.
Now: E 53 AMG 4MATIC / Q5 2.0TFSi Prestige
