Thread: Audi A6 C6 Leather Seats Upgrade
Results 1 to 10 of 14
  1. Audi A6 C6 Leather Seats Upgrade
    Mar 2012
    Slough
    I have an Audi A6 2.0 tdi 2007 (57) and have just purchased a set of electric leather seats to replace my existing cloth seats. Can anyone with experience out there tell me if there is already a wiring loom in the car to allow an immediate upgrade or will I have to have it retro-fitted? If a retro fit can you recommend someone. I'm based in Berkshire in the UK. Many thanks.
    Kind Regards,
    b4abu
  2. Re: Audi A6 C6 Leather Seats Upgrade
    Apr 2012
    Aylesbury, Bucks
    A simple google returned this....
    If your current car only has electric lumber support, there will only be 2 0.5mm wires going into the re plug under the seat base. One of these is battery live and the other is body earth. If you fit full electric seats, ie S4 Recaro you will have to replace the 2 0.5mm wires with 2.5mm wires. The pin designations are the same, just pick them out with a small screwdriver (or proper tool !!) Then run the 2 uprated 2.5mm wires straight to the terminal 30 connection under the relay plate on the drivers side, via a 20amp fuse. All of the electric seat functions, except heatinr anrcarried out by these 2 wires. If youwant to fit the heated seat loom, your best bet is to purchase the exact loom fro www.kufatec.de for about £40. These plug into the heater control unit and then into the wiring plug under the seat. Easy job done. If you rally want to go mad, once you've fitted the heated seats, you can fit the heated steering wheel that runs off the drivers heated seat switch ! Even easier to wire up as you only run the small loom from the steering wheel control unit to the wheel itself andthen code up with the laptop !!!!
    Hope this is of some help to someone.
    Sounds a bit daunting, but if you need more info, PM
    Cheers for now !!
    However...
    This will work but you wont get the memory seat function,load of crap if only you drive the car anyway.
    But then again....
    Agree with you but not all recaros had the memory function.
    It's a little bit more tricky if you want memory as you will need the control unit and doors switches. Not impossible though !!!
    Always up for a challenge :-)
    Happy Days !
    2018 (2017MY) S3 2.0TFSI Sportback Quattro S-Tronic in Nano Grey Metallic.
    Black Edition, Reversing camera, Parking System Plus, Hill Hold, Super Sports seats, heated, Dipping exterior mirrors, B&O, Advanced Key, Magnetic Ride, Red Calipers, 19x8J 5-V-Spoke wheels in matte titanium.
  3. Post Re: Audi A6 C6 Leather Seats Upgrade
    Mar 2012
    Slough
    Hi rafletcher,
    That is very useful information. Thanks for that.
    In fact I have 2 connectors already under the seat; a yellow one for the airbag and a black one with the 2 x 0.5mm wires as you suggested (most likely lumbar support). However, the electric seats both have 3 connectors, 2 as mentioned and a red one with 2 x 2.5mm wires. I take it that from what you're saying I can get the seat fully operational by just replacing the 2 x 0.5mm wires with 2.5mm wires on the black lumbar support connector. Do I then connect the wires from the red connector to these as well (off course with an appropriate fuse in between)?
    This came out of the breaking car:
    I take it that the existing red connector is for the other operations of the electric seat i.e. up/down & backward/forward?
    Once again thanks for all the information . Just got to wait for some decent weather. Unfortunately snow has been forecast for the weekend
    Regards,
    b4abu
  4. Re: Audi A6 C6 Leather Seats Upgrade
    Oct 2010
    Berkshire, UK
    Out of interest, which breakers yard did you get the parts from. Is there anything else on the car that may be of use (Xenons, BOSE etc). I am based near you!
  5. Re: Audi A6 C6 Leather Seats Upgrade
    Mar 2012
    Slough
    Hi JoshA6,
    I picked up the seats from Manchester. They're not a breakers but a small private garage.
    Most of the car had been stripped bare. If you want to contact them first I'd suggest you call them first before making the trip.
    Their details are:
    Autodeutsch Ltd
    Norton street
    Miles Platting
    Manchester
    M40 8EH
    0161 205 2732
    Good luck.
  6. Re: Audi A6 C6 Leather Seats Upgrade
    Sep 2012
    Whitstable, Kent
    12 Post(s)
    What about cars with no electric lumbar support, would it be possible to run the wiring to fit electric seats then? I don't specifically want elecy seats, but i will be on the hunt for some S Line seats in the not too distant future and it would be handy if i don't have to be too picky if a good deal comes up. My current seats are bargain basement, i don't even have tilt
  7. Re: Audi A6 C6 Leather Seats Upgrade
    Mar 2009
    Montenegro
    13 Post(s)
    So physically they fit without any adjustment. I suppose that electronically they can be powered wirhout any issue, only concern is if airbags are compatible with C6 airbag system.
    Maybe, in some future, I will exchange my C6 front seats with C7 (hoping that they are more comfortable)
    Sent from my LG-D802 using Tapatalk
    Audi A6 Sedan C6 2.0 TDIe 2011 Condor Grey metallic
  8. Re: Audi A6 C6 Leather Seats Upgrade
    Sep 2012
    Whitstable, Kent
    12 Post(s)
    Oh lol, no i actually have a C7 now, was trying to be funny Sorry for the confusion!
    57 A6 2.0 tdi 140 SE. Standard except for MMI Basic + and a remap by Expert Tuning, and a want list as long as the equator!
  1. Question Leather interior upgrade, Which seats will fit, A4 B5 saloon.
    By Bigzed in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-11-2012, 06:41 PM
  2. thinking of changing my standard seats for half leather/leather.
    By pablo66 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 23-06-2012, 08:13 PM
  3. Please Help Audi A4 1.8T (B5) Leather Seats
    By marf100 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-11-2011, 09:59 PM
  4. Please Help Leather/Alcantara Protector (Audi A4 Avant Executive S-Line) seats?
    By tigersargyle in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 04-08-2009, 06:50 AM
  5. Please Help Audi A6 Avant Leather Seats
    By SteveTA6 in forum New Member Introductions
    Last Post: 14-06-2009, 11:36 AM
