Thread: Conversion queries
  1. Question Conversion queries
    Sep 2009
    Cadiz Spain
    I have a 1988 MK1 karmann cabriolet with a 1.6 carb engine (not sure on the engine code)
    My plan is to convert to a KR 1.8 16V from a mk2 GTI.
    I have read the guides posted around the web but I still have a few questions.
    Firstly, because mine is a cabriolet, are there any major differences for the swap?
    Because mine is a carb, are any extra pieces needed to convert it to a 16v injection?
    I would be buying a donor car to convert, so I don't have to hunt down pieces from scrappies etc.
    Until this can be done, are there any short term ways I can improve my carb engine's power? new plugs and leads helped but id like it to have enough power to not need a gear change to go up a hill.
    Underwoodr
  2. Re: Conversion queries
    Gwent
    I guess you would need the fuel pump, all pipes and relay. exhaust system is likely to be too small a bore for the full benefit of the engine.
    If you run super + fuel you could bump the timing a few degrees, would liven up the car a bit in the meantime. The KR drinks 98 R.O.N anyway, so get used to it..
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  3. Re: Conversion queries
    Sep 2009
    Cadiz Spain
    Thanks for the info
  4. Re: Conversion queries
    1836 Post(s)
    There are a number of ways to approach this conversion and I could write a book on it so it would be better to ask individual questions as you approach the jobs. The fuel lines are an issue and I would recommend you get them from Crazy Quiff as they are a lot easier to work with although I prefer the rigid lines which at present cannot be bought. The most difficult part is going to be the electrics’ as you car has nothing that will be of the slightest help. I can email you are wiring diagram for the late fuse box method or the early system is in the Haynes Mk2 manual. This is the wiring coming out of the bulkhead on a typical conversion I used to do when this was popular.
    This particular car was a 1.6 GTI with the early fuse box so it was much more complex as I converted it to the late Mk1/early Mk2 pre 1990 fuse box to make it easier and more reliable. Of course you need to start this part of the job by removing the under dash cross brace which gets right in the way.
  1. Golf Mk 7 queries
    By cs2009 in forum Golf MK7 - 2013 - 2019
    Last Post: 08-10-2012, 06:31 AM
  2. HELP loads of queries
    By bond007 in forum In Car Entertainment
    Last Post: 10-05-2010, 03:33 PM
  3. Coolant Queries
    By AJA in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-12-2009, 10:49 AM
  4. Functional Queries
    By Pibsy in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 19-10-2008, 07:41 PM
  5. Sunroof Queries!?!
    By andy_c_v in forum Golf MK4 - 1999 - 2004
    Last Post: 04-05-2008, 04:51 PM
