Thread: Audi A3 1.9 TDI AHF Engine Speedo stopped working and lack of power
  1. Audi A3 1.9 TDI AHF Engine Speedo stopped working and lack of power
    Jan 2009
    Nuneaton England
    6 Post(s)
    Hi All
    I have Audi A 1.9TDI AHF - 200,000 miles and going strong (usually)
    On the way home from work today it suffered a few issues:
    Speedo stopped working - It then started going up and down has I pressed the throttle up and down
    I also noted when the speedo was not working there was lack of power / no torque - When the speedo decided to work the engine appeared to have more power
    Cruise control has also stopped working (This was retro fit, to help preserve my licence)
    Thanks in advance
  2. Re: Audi A3 1.9 TDI AHF Engine Speedo stopped working and lack of power
    Jan 2009
    Nuneaton England
    6 Post(s)
    Hi All
    Please any idea's it did the same tonight, Speedo stopped and no low down power / torque
    A few minutes later the speedo was going up and down when I pressed the throttle and power seemed to return
    HELP
  3. Re: Audi A3 1.9 TDI AHF Engine Speedo stopped working and lack of power
    Mar 2008
    High Wycombe
    The first thing to do is check the fuses. It sounds like it's intermittent, so I'd take the fuse out, check it for cracks or corrosion, then replace it.
    A fault code read and reset would also be a good idea.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  4. Re: Audi A3 1.9 TDI AHF Engine Speedo stopped working and lack of power
    Aug 2011
    Meath
    By speedo do you mean road speed or engine RPM? It needs a scan there could be a few reasons for this problem
  5. Re: Audi A3 1.9 TDI AHF Engine Speedo stopped working and lack of power
    Jan 2009
    Nuneaton England
    6 Post(s)
    WOW its cold out
    Doctle Odd - Speedo (Road speed)
    NickPicks Do you mean check all fuses or a specific one?
  6. Re: Audi A3 1.9 TDI AHF Engine Speedo stopped working and lack of power
    Mar 2008
    High Wycombe
    Quote Originally Posted by mumutley View Post
    I'd check any relating to the dash panel, but since i don't know which ones they are, I'd personally start at the top and work my way down.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  1. Supermarket Diesel Passat B6 2.0 TDi BKP Engine Poor Power Lack of power
    By woody80uk in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-03-2012, 11:29 AM
  2. Dash Stopped Working-Speedo,Fuel Gauge,Rev Counter etc....HELP!!
    By stevesos in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-01-2012, 01:10 PM
  3. Golf 1.4 petrol speedo stopped working
    By farmamick in forum Golf MK4 - 1999 - 2004
    Last Post: 18-01-2011, 11:44 PM
  4. 98 passat tdi lack of power + all internal lights not working
    By desperado in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-05-2009, 12:31 PM
  5. Audi TDi Odometer + stopped working...HELP!
    By John R. O'Neon in forum 80 - 90
    Last Post: 12-07-2007, 09:31 PM
