Thread: AYM Engine compatibility with AFB
  1. AYM Engine compatibility with AFB
    Jan 2013
    Denmak (DK)
    i am about to put a new engine in my A6 2.5TDI born with a Afb engine
    six speed manuel gearbox , i can get hold of a low miles AYM engine ,
    it is complet unit with no mossing parts at all , but is there any problemes
    when my car is used to have a AFB engine ???
    can i you the AYM Fuel pumpe ?
    i think the rest of them is the same
    Best regards from Casper
    Denmark (DK)
  2. Re: AYM Engine compatibility with AFB
    london/ UK
    You will need to change the sump as the AFB does not have oil level sensor, vacuum pumps are different but you can just mod the pipe to work and you will need to swap the AFB pump onto the AYM engine. Everything else is the same externally- most differences are with the strenghtening cast ribs and inside bits: rods, pistons,etc.
  3. Re: AYM Engine compatibility with AFB
    Jan 2013
    Denmak (DK)
    Thank you very much for your reply .
    It is no problem for me to move the sump and my own fuel pumpe .
    the guy iŽam buying it from does also have a BDG engine that have driven a littel more kilometers
    it this a better engine to put in it ?
    i have read that they also have bad camshaft and will kill til cylinderheads when they go bad ?
  1. 2.5 TDI AYM engine Hard starting now wont start
    By westfield1962 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-09-2013, 10:25 AM
  2. Newbie questions 2.5 TDI AYM Engine Code - Power Steering & Termostat
    By shockyUK in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-12-2012, 07:40 PM
  3. A4 AYM engine starting issue
    By lojiuk in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-11-2010, 08:10 AM
  4. A4 2.5 tdi AFB Engine knocking
    By johnbuz in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-07-2010, 09:43 AM
  5. A4 AFB 2.5tdi turbo compatibility
    By rob7706 in forum Archive posts
    Last Post: 25-04-2007, 09:52 AM
