Thread: Whats your ECU / Module 01 coding II...
Results 1 to 10 of 18
  1. Whats your ECU / Module 01 coding II...
    Sep 2011
    Lurking over a keyboard ...
    Hi peeps ...
    What is the "Coding II" of your engine module / ECU / Module 01 ...
    Mine is all zero's... which usually means not coded correctly...
    Here's the advanced ID...
    Here's VCDS log of that section as well...
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 4F0 910 401 A HW: 4F0 907 401 A
    Component: 3.0L V6TDI G000AG 0020
    Revision: --H01--- Serial number:
    Coding: 0011372
    Shop #: WSC 06256 200 1048576
    VCID: 1A31F983D58873C8CF8
    No fault code found.
    Readiness: 0 0 0 0 0
    Here's another image to ref...
    Now here's the original VCDS log before I had the ECM software update (downgrade)...
    Part No SW: 4F0 910 401 L HW: 4F0 907 401 A
    Component: 3.0L V6TDI G000AG 0040
    Coding: 0011772
    Shop #: WSC 02334 785 00200
    VCID: 254BDA7FECFA26C
    The reasoning for the update (downgrade) was mine is a very early 3.0 TDi without DPF, I have a idle issue an Audi TPI/TSB suggests fix is change to SW: 4F0 910 401 A originally my car was SW: 4F0 910 401 L and if you look at ECU label photo that's what it was from the factory...
    Are you well probably not as much as I am! ... any welcome... and thanks fellow members ...
  2. Re: Whats your ECU / Module 01 coding II...
    Feb 2011
    Bergen, Norway
    BTW, I found this as I have a VCDS scan on my computer now:
    Part No SW: 4F7 910 401 D HW: 4F0 907 401 C
    Component: 2.7L V6TDI G000AG 0010
    Revision: --H05--- Serial number:
    Coding: 0011372
    Shop #: WSC 00772 218 181289
    VCID: 244C1D46E7853E3865D
    Readiness: 1 2 0 0 0
    Will check coding II later tonight.
    I've got a BPP engine, car's produced in october 2007 (2008 model) and is a 2,7TDI with DPF
    2008 A6 Allroad 2,7TDI Q TIP - MMI high, SDS, TV, Parking +, BOSE Surround, Advance Key, AFS +
    2011 A1 1.2 TFSI Sport - Navi, BT, AMI
    1 1 0
  3. Re: Whats your ECU / Module 01 coding II...
    Feb 2011
    Bergen, Norway
    1 1 0
  4. Re: Whats your ECU / Module 01 coding II...
    Sep 2011
    If I'm ever in Norway & if you'd meet me I'd like to shake your hand ... and bring you a bottle of brandy as its cold!...
    Really THANK YOU!
  5. Re: Whats your ECU / Module 01 coding II...
    Feb 2011
    Bergen, Norway
    Quote Originally Posted by gupsterg View Post
    Really THANK YOU!
    You'll get a bottle of aquavit in return, for helping me out a dozen times... So bring the brandy on BTW: they are probably starting up the Newcastle-Bergen Ferry again soon You're welcome
    1 1 0
  6. Re: Whats your ECU / Module 01 coding II...
    Sep 2011
    So from another forum buddie ...
    Quote Originally Posted by sparker
    Engine 01 coding II has the same screen shot as you e.g. coding is 00000
    My software SW 4F0 910 402 S
    Soft coding is same as yours 0011372
    Advanced Id
    BPG 810
    Rev 03
    21/09/06
    Test stand 1883
    0205
    Not been Flashed so
    0
    0
    000000000
    000000001
    000
    00.00.00
    Software A4.7.7
    2006 A6 3.0 TDi Allroad
  7. Re: Whats your ECU / Module 01 coding II...
    Sep 2011
    After mulling over all past data I could relating to my issue the TSB was not applicable to my car...
    So the downgrade of ECU software was not the fix...
    Now I will be investigating how to get it reverted to original one...
    3.0 l V6 TDI; brief engine speed fluctuations after the start.
    Technical background
    The throttle valve is quickly closed after the start. This leads to a greater exhaust gas recirculation
    volume and brief idle speed fluctuations.
    Production change
    Engine software updated from Chassis No. 4F*5N104874
    So if your VIN is higher than xxxxxx4Fx5N104874 it does not apply to vehicle, mine is the range of xxxxxx4Fx6Nxx4999...
  8. Re: Whats your ECU / Module 01 coding II...
    Dec 2012
    Bulgaria, Sofia
    Most of the time software update TSBs become obsolete because a new/revised part number has been manufactured. For example if you install the newer: glow plugs or BD injectors or CR rail regulator or AT oilchange you HAVE to be to the latest software possible. Otherwise you are going to drive the new/revised parts using the old software which was written in order to correct the problems with the old parts - NOT a good idea, at least some side effect will be inevitable!
    Therefore my advice is to update to the latest possible software, having in mind that you have already changed a lot of the main parts with the present state index version.
    wish you LUCK!
    1 1 0
  9. Re: Whats your ECU / Module 01 coding II...
    Sep 2011
    I agree fully mate ... I already had the lastest part no/rev of software for ECU... but sometimes the easy fixes are so enticing!...
    Coding: 0011772
    Quote Originally Posted by a8 tech View Post
    checked your ecu data and your sw version 040 is the latest for bmk so no updates
    I never gave A8 my VIN nor did he ask , I never cross ref'ed VIN myself ... my head was really boggled with all that has been going...
    An easy human mistake on my part and will learn from it ...
    I find it easier to answer a question than sometimes to help myself as my emotions cloud my mind ....
    I made the choice so it rest on my shoulders ... this post is not directed at anyone but just as my own statement on the forum ...
  10. Re: Whats your ECU / Module 01 coding II...
    46 Post(s)
    2008 3.0 TDi ASB with 79820 on the clock.
    1 1 0
  1. Question Need help coding in handbrake control module
    By lpm150689 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-04-2012, 05:12 PM
  2. Control Module Coding?
    By Zeb in forum South West England
    Last Post: 11-05-2010, 03:17 PM
  3. A4 CCU module coding goes to: 000000
    By novadan in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-06-2009, 04:04 PM
  4. Vag-com: Long coding for comfort module
    By landspd in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 17-09-2008, 12:36 AM
  5. Problem coding the instrument module????
    By henryaga in forum TT - 8N Forum - 1998 - 2006
    Last Post: 15-07-2008, 03:14 PM
