Thread: Audi A6 C6 avant MMI not working
Results 11 to 20 of 21
  1. Re: Audi A6 C6 avant MMI not working
    Sep 2011
    Lurking over a keyboard ...
    Quote Originally Posted by flyby75 View Post
    Unfortenately the Audi specialist couldn't read anything out with VCDC
    Did the specialist do MOST loop test (look at VCDS link) with bridges in place? or just an "Autoscan" for fault codes?
  2. Re: Audi A6 C6 avant MMI not working
    Jul 2011
    london
    He tried a VCDS link with no bridges in place, and all equipment still connected.
    He told me that it was completely dead, even the diagnostic of the whole car....
    But I am not sure how much of an Audi specialist he is on this subject
    I have 2 loop bridges ordered with Audi, and they should come in tomorrow or so.
    When I am back in the country in a few days, I can do some better testing!
  3. Re: Audi A6 C6 avant MMI not working
    Jul 2011
    london
    Hello,
    Well I had time to have another look today.
    I bought 2 Audi optical loop connectors....
    -I put an optical loop connector between the BT phone ECU...still not working.
    -Next I put an other loop connector where the Bose amp was....MMI is working again
    So unfortenately the Bose amp is broken, but at least I know this now.
    I have someone looking at the amp to see if it can be fixed.
    Otherwise I have to find a second hand one.
    It' s a Bose 4F0 035 223 D.
    Can anyone perhaps tell me if I can buy an amp with a different last letter, or does it have to be "D" model?
    I know I have to get component protection off.
    Hope someone has experience with this?
    Thanks!
  4. Re: Audi A6 C6 avant MMI not working
    Sep 2011
    Below is list I can see where yours appears...
    4F0 035 223 A
    4F0 035 223 D
    4F0 035 223 F
    4F0 035 223 G
    They each have a VIN range associated with them... but when selecting 4F0 035 223 D it supersedes to 4F0 035 223 G ...
    You will need component protection removed when fitting the replacement AMP, regardless of new or used...
    Link:- Audi VW Volkswagen Skoda Seat Independent Specialist London
    Above garage is forum sponsor, close to you, can remove CP & code for you, charge vs Audi 1/2 the price...
    May also be able to advise on P/N compatibility... I'm only reading a screen as a meddling owner ...
    1 1 0
  5. Re: Audi A6 C6 avant MMI not working
    Jul 2011
    london
    Thanks for the quick reply!
    I will contact him if mine is beyond repair...
  6. Re: Audi A6 C6 avant MMI not working
    Jul 2011
    london
    Hello,
    I just wanted to thank everybody for the help.
    It is all working again.
    I bought an amp from ebay with end letter G.( had a 4F0035223 "D" before)
    Build it in, and just had the component protection removed by Audi.
    nice to have some decent Bose sound again in the car!
    1 1 0
  7. Re: Audi A6 C6 avant MMI not working
    #17
    Sep 2011
    "Luv it when a plan comes together"
  8. Re: Audi A6 C6 avant MMI not working
    #18
    Apr 2017
    Leicestershire UK
    I have the same issue with the A6 C6 Avant (2007) where water has leaked from the washer pipes onto the mmi unit. If I find a replacement radio unit, can I just swap it with the current one? Does anything need to be done to the car? Im struggling to find anyone who can help me with this!
  9. Re: Audi A6 C6 avant MMI not working
    #19
    Jul 2018
    Kent
    If the loop break doesn't work then try the loop break on more than one device. Other option is to disconnect all devices optic cables. I have 3 in the boot, one under carpet passenger side, CD changer and 2 behind glove box. Shine a torch down the cable and work your way round the loop. I did that to find a cable was damaged between the CD changer and bt module. I have the map written down at home so if you want more help then private message me.
  10. Re: Audi A6 C6 avant MMI not working
    #20
    Jan 2010
    kent, england
    Is there any way to safeguard against this happening?
    Mike.
  1. Audi A6 Avant 1.9tdi 130pd turbo not working
    By barney2 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 02-03-2013, 12:04 AM
  2. Audi A6 MMI problem, not working.
    By rempsel in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 23-10-2012, 08:48 PM
  3. Audi a6 avant mmi no sound & crackling from speakers
    By kdeedub in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 12-05-2012, 05:55 PM
  4. Audi a6 2009 avant mmi ??'s
    By V6mxy in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 14-03-2012, 02:16 PM
  5. Audi A6 Mmi Upgraded To 3d Map Phone Stopped Working
    By daklow in forum In Car Entertainment
    Last Post: 12-09-2008, 09:57 PM
