Thread: Removing Alternator Clutch Pulley 1.9TDi With Alternator And Viscous Fan Still in Situ
  1. Removing Alternator Clutch Pulley 1.9TDi With Alternator And Viscous Fan Still in Situ
    Sep 2008
    Have obtained tool to remove clutch pulley, and after looking at it would it not be possible to do the following?
    Loosen splined bolt with belt still attached using tension on belt to stop it rotating.
    Release tension on belt with 19mm spanner, lift it off the alternator pulley, and then completely remove the clutch, it looks as if there is enough space for it to come out between the blades of the fan.
    Do the reverse to refit.
    This all looks a bit too simple as the Haynes says to remove the front end, viscous fan and alternator, am I missing something?
    Thanks chaps!
  2. Re: Removing Alternator Clutch Pulley 1.9TDi With Alternator And Viscous Fan Still in Situ
    Aug 2011
    Meath
    Remove the alternator. It's easy 2 bolts on the alternator, there's a cutout in the viscous fan for the bolt next the engine block. lift it out. If something slips and punctures the radiator you'll have to remove the lock carrier then, this way you can do it on a bench or the ground, less than an hours work, hope this is helpful
  3. Re: Removing Alternator Clutch Pulley 1.9TDi With Alternator And Viscous Fan Still in Situ
    Sep 2008
    Thanks for your quick reply, have seen your post on another thread with pictures, I follow up to the bit where you get the alternator out however I don't quite follow the next three pictures where you use the T50? Probably because I'm a bit thick!
    Is the pulley clutch bolt normal removal? ie is it anti clockwise?
    Thanks Again!
  4. Re: Removing Alternator Clutch Pulley 1.9TDi With Alternator And Viscous Fan Still in Situ
    Jan 2011
    derby UK
    I've replaced the alternator without removing the fan. The bolt was replaced then with bolt from b5 which is a bit shorter and comes out a lot easier.
  5. Re: Removing Alternator Clutch Pulley 1.9TDi With Alternator And Viscous Fan Still in Situ
    Aug 2011
    Meath
    You don't need to remove the viscous fan so ignore that bit. hold the alternator shaft with a t50 and turn the tool with a spanner, if you have a gun you can spin it off, loosens anti-clockwise
  1. Alternator Clutch Pulley
    By alphamike583 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-10-2013, 09:43 PM
  2. Question Removing the viscous fan pulley.
    By npellew in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-10-2009, 07:39 PM
  3. Alternator Clutch Pulley
    By Withnail in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-10-2009, 10:51 PM
  4. Alternator Clutch Pulley
    By Vingster in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-09-2008, 11:15 PM
  5. A6 1.9TDI Alternator Pulley
    By johnnywishbone in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-10-2007, 11:46 AM
