Re: vcds help. –
01-01-2013,01:23 PM
From that little snippet you gave sounds like you are re-coding a module that has not been re-coded before. Nothing to worry about, but VCDS needs to send a 'Dealership Workshop Tool' number to the module being re-coded. Normally, if it finds this data already in a module - it sends it back in the background. This info is just so [theoretically] workshops can see which workshop was the last to re-code or adapt a module in the car.
So if VCDS sees all zeros in the Workshop codes it will suggest 1234 etc. It doesn't matter a jot to the coding what numbers are there - as long as they are non-zero.
If you want to make it look plausible; place '210' as the ZV/Importer, '00780' as the code (WSC) and anything you like for the Equipment Number. If your local dealer has ever carried out a service; their details will be stored in the Instrument Cluster at address 17 - and you see the info you require on either the module front screen or just before you do a re-code.
MY2009 A4 Saloon 2.0 TFSI quattro S-line Exec - Aruba Blue, 19" alloys, Convenience Key, Sunroof, Adaptive Lights, Anti-dazzle Folding Mirrors, Rear Sun Blind, Heated Full Leather with Memory, Storage/Light Packs, Audi Hold Assist, Adaptive Cruise Control, Parking System Advanced, Privacy Glass, Rear Airbags, TPMS. MMI 2G with B&O Sound System, DAB Radio, DVB TV, AMI and Bluetooth Phone prep High with Privacy Handset.
