Thread: 2.5tdi timing adjustment
  1. 2.5tdi timing adjustment
    Jan 2011
    ipswich uk
    hi hope someone can help i have 2.5tdi bdg engine car was registered dec 2003 the timing is retarded using vag com graph i removed upper belt cover to adjust as per instructions instead of finding 3x10mm bolts with elongated holes on sprocket i have 3x10mm allen key bolts with what seems no adjustment any ideas thanks
  2. Re: 2.5tdi timing adjustment
    Jul 2011
    Norway
    Allen key yes, elongated holes, no? Look again!
  3. Re: 2.5tdi timing adjustment
    Jan 2011
    ipswich uk
    thanks for reply will look again what is best way to move pulley
  4. Re: 2.5tdi timing adjustment
    london/ UK
    Large screwdriver and hammer, just tap the pump sprocket either way: clockwise to retard and anti clockwise to advance...
  5. Re: 2.5tdi timing adjustment
    Jan 2011
    ipswich uk
    thanks
  6. Re: 2.5tdi timing adjustment
    Jul 2011
    Norway
    Quote Originally Posted by adamss24 View Post
    Clockwise to advance, and opposite, might works better. Also if you just leave the hammer and use the screwdriver to gently push the alignment arrow at the tentioner againest the cars right side, you can easily turn the
    sprocket by hand, small steps! The 3 allen key is torqued by 20 nm.
  1. how to check/alter timing on a 2.5tdi ?
    By white.akita in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-02-2012, 11:05 AM
  2. How to setup timing on 2.5TDi using VAG COM
    By toadus in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-03-2011, 07:11 PM
  3. Please Help 17939 - P1531 - Camshshaft Timing Adjustment: Open Circuit
    By skipi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-06-2010, 11:01 PM
  4. T4 2.5Tdi timing marks
    By matp in forum The Commercial Range
    Last Post: 26-11-2008, 04:47 PM
  5. Timing Belt A6 2.5TDi
    By lennymfo in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 30-06-2008, 12:44 AM
